grinchsr 675 #1 Posted 17 hours ago I am going to be servicing the trans on my 516H and the manual is calling for straight 20W oil which is hard to find has anyone found a substitute? Share this post Link to post Share on other sites
ri702bill 13,356 #2 Posted 17 hours ago (edited) McMaster Carr may have what you need... They carry a few 20W industrial oils. Perhaps a Mobil DTE product would be compatable and work. Readily available at Industrial Supply stores... Edited 17 hours ago by ri702bill Share this post Link to post Share on other sites
Lagersolut 806 #3 Posted 15 hours ago The jungle site has a gallon of 20w for 45 - not sure its applicable to this application - $45 ComStar Bearing Assembly Lube Oil 1 gal SAE 20 Non-Detergent AGMA #2 Grade Prevents Against Rust & Ware, Prevents Gumming, Long-Lasting Lubrication, Withstands Extreme Pressure, Made in USA Share this post Link to post Share on other sites
grinchsr 675 #4 Posted 15 hours ago I will take a look. Thanks for the info Share this post Link to post Share on other sites
grinchsr 675 #6 Posted 14 hours ago Exactly what I needed because 20W oil is crazy hard to find. Thank you Share this post Link to post Share on other sites
ri702bill 13,356 #7 Posted 6 hours ago 8 hours ago, gwest_ca said: Interesting note in the Service Bulletin about filtering the oil from the container prior to adding it into the trans.... and the 8 speeds will work with a cup of water inside!! Share this post Link to post Share on other sites
peter lena 10,118 #8 Posted 3 hours ago @grinchsr 0- 20 oils are a base line today , thats also a better range for , start ups , pete Share this post Link to post Share on other sites
