grinchsr
Eaton 7 Oil
grinchsr
I am going to be servicing the trans on my 516H and the manual is calling for straight 20W oil which is hard to find has anyone found a substitute?
ri702bill
McMaster Carr may have what you need...  They carry a few 20W industrial oils.
Perhaps a Mobil DTE product would be compatable and work. Readily available at Industrial Supply stores...
Edited by ri702bill
Lagersolut
The jungle site has a gallon of 20w for 45 - not sure its applicable to this application - $45
ComStar Bearing Assembly Lube Oil 1 gal SAE 20 Non-Detergent AGMA #2 Grade
Prevents Against Rust & Ware, Prevents Gumming, Long-Lasting Lubrication, Withstands Extreme Pressure, Made in USA
grinchsr
I will take a look.  Thanks for the info
gwest_ca
grinchsr
Exactly what I needed because 20W oil is crazy hard to find.  Thank you
