Fordiesel69 274 #1 Posted 11 hours ago 2 weeks into ownership i am genuinly not liking working on these. The engine compartment is jammed tight and it seemingly has twice the electrical system that the gas models have. Starts and runs great but overall it looks like the engine has some very odd parts that will be unobtainium. The radiator and hoses for one, and the total exhaust system looks very rare. If it cracks and breaks off it would appear the only option is to have something custom made. The water pump as a normal wear item looks impossible to change without pulling the engine. What are the weak areas of these tractors? Share this post Link to post Share on other sites
ri702bill 13,352 #2 Posted 10 hours ago (edited) Kevin @Pullstart should chime in regarding excessive wear in the front axle pivot on the frame. Best to fix it before it breaks. He has done his. Edited 10 hours ago by ri702bill 1 Share this post Link to post Share on other sites
Pullstart 71,538 #3 Posted 5 hours ago You should scrap it. I’ll even haul it for ya! These are super heavy duty machines, with a frame nearly the strength of a truck. Mine is just a 20 hp gasser flavor, so the diesel related items I am not familiar with other than seeing @Shynon’s 4x4 articulated custom build. I believe he has an engine with some broken parts, from the @WHX?? plow day in October. Here’s a link to the front axle pivot repair. It was the only bad design I can find on the frame work itself. Share this post Link to post Share on other sites
