8ntruck
Hitch Height
8ntruck
I've been towing with a 2015 Ram 1500, using a hitch with a 2" drop.  This made the trailers I tow run with ith the toung running slightly down hill.
On the last trip we took with the ALiner, I switched to a zero drop hitch.  This has the toung of the ALiner real close to level.  This change made the ALiner 'feel' better to tow over the 2" drop hitch.
I'm  wondering why this is.  Part of me thinks it feels better, just because I think it should help.  Other parts of me wonder if the toung angle turns any camber in the trailer wheels into tow in or tow out, or maybe the small shifts in the trailer's center of gravity in relation to the wheel hubs changes the towing dynamics of the trailer.
Thoughts?  Comments?
Bar Nuthin
Close to level is usually best. Too high shifts the load backwards and can make a trailer prone to swaying. To low shifts the weight forward and can lighten the front wheels of the truck and make them feel less in touch with the road.
Edited by Bar Nuthin
typo
SylvanLakeWH
:text-yeahthat:
I try to run them roughly level. However, load distribution and tongue weight are factors for empty vs. full load... I always load my utility trailer so there is adequate tongue weight to keep the trailer firmly on the hitch.
Tonytoro416
Overall trailer length with also effect how this feels ( better or worse)
my little 12 ft utility trailer has to be pretty level when loaded on my truck. Tongue angled forward or down makes the trailer almost constantly wagging slightly when empty.  My longer trailer doesn’t get the sway like the shorter utility does
