ohiofarmer
Trouble tree for hard engine turnover
ohiofarmer
 I am trying to evaluate some engines that ran pretty well not that long ago. I am also trying to figure out what to try first. The symptoms are like the battery has not enough oomph to turn things over, but when I swap the apparently weak  batteries to a good runner they have plenty of spin.
    Here"s what I am thinking the order should be.
1. Remove spark plug and spin the engine to confirm the starter is not dragging { at least under light load}  this also would confirm that pistons are not frozen.
2. Clean the ground from the battery to the frame and clean the main connections
3.  Put the spark plug back in and note the difference between batteries tested
4.. Swap starters to by trading a known good one if problem does not correct
5. Check valve clearance to make sure there is no tight spot.
6. Anyting else you guys think of , or suggestions that I am doing things in the wrong order.
   Thanks in advance I will keep you posted what i find out.   I want to have a dedicated snow blade mounted and ready and If all else fails there is a 520 with a pull rope or electric start . Come to think of it the 14 horsepower Predator is both pull and electric start. I will get some pictures of the tractors.
Edited by ohiofarmer
ri702bill
OK... you may wish to do the electrical connections first - and charge the battery. Which #3 do you want to do next??:lol:
You may wish to check the color of the actual spark too. Ditto for the fuel system too.
Snow plowing - check the condition of the "F" plate!!
ohiofarmer
Numbers Fixt. Thanks
ebinmaine
You're headed a good direction but again I remind the class.
These are DC systems.
Direct. Current.
Bad ground ANYWHERE is a bad circuit.
No ground = no direct current.
  • Excellent 2
953 nut
Sounds like a for sale ad,    ran well when parked.      :hide:
OK, now lets get down to getting your engine running well.
Clean and tighten ALL electrical connections including grounds, any bad connection will prevent the system from working properly.
If you use an automotive jumper cable from the battery - to the engine frame does the starter work better?
If you use an automotive jumper cable from the battery + to the starter does the starter does the starter work better? If this is an Onan the starter wire would be the output of the attached solenoid, the lower on that goes into the starter (be very careful not to short the jumper to the starter or engine.
Since the engine ran well before I doubt that these would be productive uses of your time.
What ignition type are we talking about, battery or magneto?  If you have a battery ignition clean the points by slowly dragging a dollar bill through the closed points contacts.
When the engine turns over is gas getting to the carburetor? No gas to ignite will not help the engine turn over.
8ntruck
Might be a long shot, but, is the timing set to spec?
Gasaholic
First thing, and the easiest to do, if you practice, is learn how to do a voltage drop test , and what the results actually mean.  You'll need a good DVOM , and it is helpful to have some specialized test leads (alligator clips, jumpers, etc - sort of an extra pair of hands) - Voltage dropping will help you pinpoint the trouble spots. Secondly, learn how to do an amps draw test (both on machine and on bench) to test a starter's amp draw - which would be the definitive way to test a starter for issues (worn brushes, sticking brushes, shorted windings, etc)  - Both of those would go a LONG way to making troubleshooting quick and easy. It'll help you spot things like poor internal connections, broken wires, all kinds of things that you can't see, but will affect how the starters work.  Most engines will have decompression mechanism that if they don't work properly can throw a "red herring" into any troubleshooting process if you aren't aware of them.  So , basically it's a simple matter of a couple of good test meters, an assortment of leads, and most importantly, an education in how the electrical systems work.  It can make the difference between a 5 minute diagnosis and a 5 hour diagnosis.  That'd cover 99.5% of every issue you might ever come across and make it dead simple.
Plenty of info in these forums on voltage dropping and amp draw testing...
Once you get the hang of those simple tests, you may wonder how the heck you ever got through life without knowing those (and probably make you your buddy's first call when they have an electrical issue to figure out)  It ain't rocket science, though judging by how some of today's techs muddle through things, you'd think it was...
squonk
My Power King has the battery in the rear of the tractor. The battery is 4 years old and tests ok but not like it was new. The positive cable was 6ga. wire about 6 feet long. A short neg cable from battery to frame. It was turning over a bit slower but would start.  I replaced the cables with 4ga. wire, I did not do anything else. When I hit the key the engine just about flies out of the tractor now.
Handy Don
As you know well, the condition of the cable, its terminators, and connections has a big effect on 12v electrical systems.
I'm curious to know the ohms of resistance in the cable you removed and your estimate of the starting amp draw of the starter. The voltage drop difference between 6ga and 4ga at 12v over 8 ft is really quite small in the 80-100 amp range.
sqrlgtr
maybe a smaller hammer or less force is needed.:ychain:
  • Haha 2
ohiofarmer
Battery ignition
ohiofarmer
 Very helpful stuff here. .I had a tooth pulled and it is cutting into how long I can spend on things for now. One thing that I found out was how much better the batteries charged up and held charge by using the little conditioning charger/ maintainers at a charge rate of either two amps or even .75 amp. I don't have a load tester but the resting voltage went up to almost 12.6
Pullstart
Mouse nest in the flywheel area?
c-series don
@Pullstart Someone say mouse nest in the flywheel?
  • Sad 1
