ohiofarmer
Trouble tree for hard engine turnover
ohiofarmer
 I am trying to evaluate some engines that ran pretty well not that long ago. I am also trying to figure out what to try first. The symptoms are like the battery has not enough oomph to turn things over, but when I swap the apparently weak  batteries to a good runner they have plenty of spin.
    Here"s what I am thinking the order should be.
1. Remove spark plug and spin the engine to confirm the starter is not dragging { at least under light load}  this also would confirm that pistons are not frozen.
2. Clean the ground from the battery to the frame and clean the main connections
3.  Put the spark plug back in and note the difference between batteries tested
4.. Swap starters to by trading a known good one if problem does not correct
5. Check valve clearance to make sure there is no tight spot.
6. Anyting else you guys think of , or suggestions that I am doing things in the wrong order.
   Thanks in advance I will keep you posted what i find out.   I want to have a dedicated snow blade mounted and ready and If all else fails there is a 520 with a pull rope or electric start . Come to think of it the 14 horsepower Predator is both pull and electric start. I will get some pictures of the tractors.
Edited by ohiofarmer
ri702bill
OK... you may wish to do the electrical connections first - and charge the battery. Which #3 do you want to do next??:lol:
You may wish to check the color of the actual spark too. Ditto for the fuel system too.
Snow plowing - check the condition of the "F" plate!!
ohiofarmer
Numbers Fixt. Thanks
  • Thanks 1
ebinmaine
You're headed a good direction but again I remind the class.
These are DC systems.
Direct. Current.
Bad ground ANYWHERE is a bad circuit.
No ground = no direct current.
