Ed Kennell
60" deck belt routing
Ed Kennell
Found this belt routing decal on a 60" deck.    Did any 60" decks have the PTO belt on the bottom pulley?
May be an image of tractor, drill press and text
cleat
My 60" deck has the PTO belt on the bottom.
172261332_Deckcompletelyrebuiltsittingonground.JPG.e982dc9526d507a19dc798aafda9f12f.JPG
Ed Kennell
Thanks Cleat...the 82yo dog is still learning.
What was the reason for this belt change on the 60" decks?   belt axle clearance, radial load on the center spindle???
Edited by Ed Kennell
gwest_ca
I will guess that it was to get the longer blades down to a maximum blade tip speed of 19,200 feet per minute.
Handy Don
I think the question is: Why is the PTO belt on the bottom? The pulley could be inverted to be big on top and small on the bottom to get the same speeds.
gwest_ca
Wonder how the spindle pulleys ended up at the correct height?
Could they just be turned over?
Handy Don
Ah, that could be it. Aligning the deck belt to match the height of the other spindles without raising the overall height above the deck.
Ed Kennell
Good discussion..:thanks:  Don and Garry.
c-series don
And it’s a real PITA to change the PTO belt if the deck is on the tractor. I had to disconnect the deck from the Mid-Mount Tach-A-Matic, then unhook the rear leveling adjustment rod to be able to lift the carriage high enough for the belt to clear the spindle. Also had to slack the deck belt with a pry bar on the tensioning pulley shaft. It’s definitely way more difficult than changing belts on a 42”-48” decks.
peter lena
@Ed Kennell @cleat , @ C- SERIES DON, that belt pulley  set up is a GOLD MINE FOR ROTATIONAL , IMPROVEMENT . lubrication , noise , whine , related BELT BOUNCE ? dare I suggest  a , lubrication , clean / flush out ?  years in on my decks , no rot / rust , and no bearing  failures , entire mule  drive set up is lucas  x tra hd  green chassis grease , walmart $ 8 , clean out  every bearing , carb cleaner flush , hand repack , pto inner  needle bearing , clean out , very light  ammount , excess flings to clutch disc . MY 3 HORSES have this in use for years  , also  sun bake my decks , for rustproofing , great opportunity, pete
Handy Don
Half the job is easy and half is hard, right?
Hard half: installing a new belt.
Easy half: hacksaw to cut and remove old belt.
:hide:
  • Haha 1
lynnmor
They wanted to add to the difficulty of installing that heavy monster by keeping the mule drive attached.  Other than that, I believe it was simply belt clearance, there isn't much space to work with.
