Pattyb 19 #1 Posted Saturday at 01:27 PM Good morning, I am hoping someone can help me because tractor repair is not my area of expertise but I can research, read and follow directions. I bought this tractor about a year ago and it does not achieve full speed, full throttle-high gear speed is the same as low gear, but it flies in reverse. It has 500 hours and I changed the oil and filter, I didn’t clean the power steering filter because all of the posts that I’ve found, this is never the solution. We disconnected the smart steer in the spring using a method found on this site but that didn’t help; it only prevented it from slowing down more while turning and that’s a good thing. Today my husband is going to help me check all the pivots and linkages but like I said, I can research and read and think the problem lies in the neutral adjustment. I was just looking at the 5XI SERIES TRACTOR HYDRAULIC SYSTEMS SERVICE MANUAL and saw a note about the pivot point and went to look at mine, the machine is not running and the pivot point look like it is facing the wrong direction. My questions are, am I correct that when you don’t have any pressure on the accelerator the pivot should be facing the other way? Can I change this while the tractor isn’t running? I realize that we should do it while it’s running to avoid creep but I took it apart so that I could clearly see everything. I am trying to avoid guessing and making it worse, that’s why I came here. Finally, since it’s apart, is there anything else that we should inspect? Thank you in advance for helping a novice. 1 Share this post Link to post Share on other sites
953 nut 70,022 #2 Posted Saturday at 02:52 PM I am not very knowledgeable on the newer Wheel Horses but some of our members like @Pullstart or @JoeM may know the answer. Share this post Link to post Share on other sites
Handy Don 17,625 #3 Posted Saturday at 04:35 PM (edited) I’ll offer some basic orientation that might, I hope, help you with diagnostics. 😁 The blue arrow points to the base of the input control arm on the hydro. It rotates when movement of the plate (yellow arrow) applies force against the eccentric (red arrow). The plate’s movement comes via a linkage to the forward/reverse motion control lever you operate by hand. The hydro pump/motor is internally symmetric making it capable of the same output speed in either direction. Moving the hydro’s input arm in one direction yields forward and the other way yields reverse. HOWEVER, those clever WH engineers shaped the slot in the plate so that (when correctly adjusted) it pushes the eccentric further in the forward direction that the reverse direction--hence the normal difference between full forward and full reverse. (Other parts of the linkage are also involved.) There are several possible reasons for having insufficient arm rotation in your “forward” direction. ONE of the reasons is addressed in Step 6, above. Over time, the sides of the slot in the plate and the sides of the eccentric can wear down through normal use leaving the eccentric “loose” in the slot. Step 6 in the manual is showing how to rotate the eccentric where it is attached to the input arm to where it is slightly narrower than the slot in the plate (to permit free movement with minimal slack) and where the end of the input arm (i.e. the bolt) is positioned in the middle of the slot. Further, it wants the “notch” in the eccentric to be pointed away from the input arm’s base at the hydro--yours is toward. Some subtle geometry dictates this. So your first step (with the engine off) is to hold the hex part of the eccentric with one wrench while loosening the bolt that holds it with a second wrench (or socket). Carefully rotate the eccentric 180º from pointing ESE (east southeast in the picture) so that it points WNW (west northwest). Retighten the holding bolt while again holding the eccentric. This might have some effect on the forward speed, but likely not a lot! Other adjustments to the linkage are likely needed to make sure that when the manual motion control lever is firmly in neutral the input arm to the hydro is centered (i.e. the tractor isn’t creeping forward or backward) and that the full range of motion control input is being transmitted to get proper rotation of the input arm. Here, though, we reach the limit of my expertise as I’ve not worked on this model. I will note that the Eaton manual for the 1100 has pretty clear instructions for adjusting the linkages so I would continue there first and, of course, come back here with questions (and pictures!) Edited Saturday at 04:38 PM by Handy Don 2 Share this post Link to post Share on other sites
oliver2-44 11,790 #4 Posted Saturday at 04:55 PM (edited) The slot shows wear on the middle left side above the eccentric. Make sure the edges of this wear area are smooth, use a file and emery cloth to remove any metal burrs. While this is probable not you mai problem, it can contribute to rough movement. Edited 22 hours ago by oliver2-44 2 Share this post Link to post Share on other sites
Pullstart 71,481 #5 Posted yesterday at 01:23 AM 10 hours ago, 953 nut said: I am not very knowledgeable on the newer Wheel Horses but some of our members like @Pullstart or @JoeM may know the answer. Sorry Mr. Richard, I don’t even know what a GT550 is 1 Share this post Link to post Share on other sites
kpinnc 19,033 #6 Posted yesterday at 01:58 AM I don't own a 5xi, but the transmission is identical to classic hydros with the only difference being how the orientation of the Eaton 1100 is mounted on the gearbox. All that said, most of the issues I've seen on classic machines are the result of slop in the linkages that actuate the cam assembly. The amount of movement between slow and fast is very small. A loose connection is plenty to rob all the travel in the linkage. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,519 #7 Posted yesterday at 12:49 PM 11 hours ago, Pullstart said: Sorry Mr. Richard, I don’t even know what a GT550 is 2005 550 5xi-Series Garden Tractor model 73561 Serial 250000001-250999999 - Formerly 522xi - This may be the same as a Ford New Holland model GT22A 2005 560 5xi-Series Garden Tractor model 73590 Serial 250000001-250999999 - Formerly 523Dxi 1 Share this post Link to post Share on other sites
Pullstart 71,481 #8 Posted yesterday at 02:21 PM Oh I know what those are! Share this post Link to post Share on other sites
953 nut 70,022 #9 Posted 23 hours ago 15 hours ago, Pullstart said: Sorry Mr. Richard, I don’t even know what a GT550 is 2 hours ago, Pullstart said: Oh I know what those are! I knew you had a 520xi and figured there might be enough similarity that you would be able to help out. Looks like @oliver2-44 has the right information. 1 Share this post Link to post Share on other sites
Pattyb 19 #10 Posted 22 hours ago Thank you! We moved the eccentric to the correct position and according to Waze on my phone I was going 6mph on the flats. We can see play in the linkage but I hadn’t taken it apart enough for my husband to reach all of it. Since it’s November in upstate NY, I’m going to call this a win for now and revisit the linkage in the spring. Thanks again! 1 Share this post Link to post Share on other sites
Handy Don 17,625 #11 Posted 18 hours ago 3 hours ago, Pattyb said: Thank you! We moved the eccentric to the correct position and according to Waze on my phone I was going 6mph on the flats. We can see play in the linkage but I hadn’t taken it apart enough for my husband to reach all of it. Since it’s November in upstate NY, I’m going to call this a win for now and revisit the linkage in the spring. Thanks again! Great! 6 mph is pretty close to the top speed for most (unmodified) WHs. When you have time/access to go through the rest of the linkages you may find some looseness that you can tweak to get the last drop of speed. . Share this post Link to post Share on other sites
