Beap52 2,517 #1 Posted 3 hours ago I've got a question about cutting aluminum storm window. The church, that I mentioned I was helping freshened up the outside, has storm windows that are mounted on the outside of the trim instead of the blind stop. Not only does it not look nice, water running down the wall can run behind the storm windows. I don't caulk storm windows because this makes them very difficult to remove plus many of them arn't very weather tight in the first place. In addition, the storm window frames are barely big enough so that many of the screws split the wood they are fastened to. I'm not sure if the photo helps, but zooming in may show storm windows before work began. By the way, the steps and ramps are now gone and replaced with a deck and new ramp. So, I would like to take about 1/2" off of the perimeter of the frames so they will set back against the blind stop. I've never sawn aluminum but see there are saw blades that will fit table saws specially for aluminum. I have a 10" portable table saw that I plan to take to the jobsite so I can cut (and adjust the aluminum frames as needed) Is there an advantage of using a 10" (100 teeth) over 7 1/4" (60 tooth) blade? thanks, Phil Share this post Link to post Share on other sites
squonk 48,256 #2 Posted 3 hours ago I'm thinking the more teeth the better. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,512 #3 Posted 2 hours ago I would use the 7-1/4" blade and just take your time because they are less expensive. Rim speed of 7-1/4" blade is about 28% slower than 10". 1 Share this post Link to post Share on other sites
Handy Don 17,600 #4 Posted 24 minutes ago (edited) 2 hours ago, squonk said: I'm thinking the more teeth the better. Absolutely agree, especially when being used on thin stock. Pro installers tend to use a compound miter or chop saw as it lets them hold the stock firmly while making the cut. Is your goal to make them narrower and shorter and reduce the glass area as well? Every storm window I’ve encountered was assembled with cast aluminum corner pieces crimped into a tubular extruded frame. These are not easily disassembled without damage. I get not wanting to caulk, for sure. If this were me, I’d seriously consider: - router the inner edges of the outer wood trim boards to the size of the outer edge of the aluminum window frame. This creates a recessed mounting surface and removes the splintered current mountings. Use a router bit with a guide bearing set properly. (Some manual chiseling to “square” the corners would still be needed) - then, because the “ledge” is still too narrow, add a ledger strip (use weatherproof glue and nails) to create a more secure (and now weather resistant attachment) - lastly, maybe, add a bit of aluminum flashing to re-direct rain coming down from the upper trim piece out away from the aluminum frame. Edited 22 minutes ago by Handy Don Share this post Link to post Share on other sites
