tallen4392 71 #1 Posted 5 hours ago Good morning my charger 12 has been used for snow removal for the last 7 or 8 years awesome machine all of a sudden it is running better only when the choke is 1/4 open when I open it all the way it starts to run rough never happened before should I remove carb and clean it or try to find a new carb the ones I see look like junk carbs where can I get a original carb ?? Share this post Link to post Share on other sites
ebinmaine 81,003 #2 Posted 5 hours ago Rebuilding your own is a pretty easy thing to do. It's just a matter of taking the time to clean things properly. Not at all complicated. The biggest thing to check for is, make sure the throttle shaft is not too loose in the bore. @76c12091520h Brian Badman may have a rebuilt carb for you. 1 Share this post Link to post Share on other sites
702854boy 1,168 #3 Posted 5 hours ago (edited) It would be better to try to remove the original carb and clean it up since as you said the repops are junk, but if you'd rather buy a carb instead of cleaning, a couple of our vendors here such as K&B Horse Parts @76c12091520h have them for sale Edit: @ebinmaine has faster fingers than me Edited 5 hours ago by 702854boy 2 Share this post Link to post Share on other sites
lynnmor 9,055 #4 Posted 5 hours ago 33 minutes ago, tallen4392 said: YOU should remove carb and clean it 1 Share this post Link to post Share on other sites
peter lena 10,099 #5 Posted 4 hours ago @tallen4392 ever drain out clean ,your fuel tank ? bet you your repetitive problem starts there, years ago did that , then installed a new flow valve , with fuel filter close to tank , been adding an ounce or two of STA BIL , fuel storage additive , to EVERY TANK TOP OFF . also dropped carb bowl , clean out , guess what ? also replaced , old original fuel hoses , NEVER HAD ANOTHER , FUEL DEBRIS ISSUE ! love repetitive issues / problems ? dissect them , make a change , this issue is like , bearing lubrication failure , what could you possibly do ? also killed that years ago , easy stuff , pete Share this post Link to post Share on other sites
ri702bill 13,242 #6 Posted 4 hours ago (edited) 1 hour ago, tallen4392 said: should I remove carb and clean it Absolutely. The best results are achieved by disassembling the carb, soaking it in an Ultrasonic cleaner - 2 or 3 cycles, and using a quality (Kohler preferred) carb rebuild kit. As @ebinmaine stated, check the throttle shaft and the bushings first for excessive wear. Both are replacable on your carb (unlike the lower HP versions). Then decide if it's keep it or toss it.... Worn bushings & shafts make the engine run too lean, as it makes for a large vacuum leak. DO check the condition of the Main mix needle - it is hollow with a small hole at the top & bottom - those must be kept open, If either are clogged, the main circuit will not be able to be properly adjusted... Edited 4 hours ago by ri702bill 1 Share this post Link to post Share on other sites
ebinmaine 81,003 #7 Posted 4 hours ago 2 minutes ago, ri702bill said: quality (Kohler preferred) carb rebuild kit. Kohler has discontinued them 3 Share this post Link to post Share on other sites
ri702bill 13,242 #8 Posted 4 hours ago Some folks still have them advertised for sale - though they are very proud of them judging by the prices... Share this post Link to post Share on other sites
Ed Kennell 47,692 #9 Posted 3 hours ago Check the two bolts that hold it to the block. I just had a Briggs that needed 1/2 choke to run. The bolts were loose permitting too much air. Share this post Link to post Share on other sites
953 nut 69,932 #10 Posted 3 hours ago 1 hour ago, tallen4392 said: all of a sudden it is running better only when the choke is 1/4 open Fuel starvation issue. Sudden leads me to believe your fuel system needs to be cleaned and inspected. Junk in the tank blocking the outlet, a gas line with a crack in it allowing air in which the fuel pump can't pump, a valve in the fuel pump that is not closing. Before you spend money on a carburetor you probably don't need look over the whole fuel system. The carb is the final component in the system but everything before it has to be doing its part too. Cleaning the carb can't hurt but cleaning the fuel tank and replacing the rubber hose and a fuel filter don't cost much and should be done anyway. By the way, if you are not using ethanol free gas you should be. Ethanol will kill small engine fuel systems, use this link to find E-Free Gas. https://www.pure-gas.org/ 1 Share this post Link to post Share on other sites
ebinmaine 81,003 #11 Posted 3 hours ago 9 minutes ago, 953 nut said: Sudden leads me to believe your fuel system needs to be cleaned and inspected. Excellent point. Always do maintenance before repairs. 1 Share this post Link to post Share on other sites
ri702bill 13,242 #12 Posted 2 hours ago 1 hour ago, Ed Kennell said: Check the two bolts that hold it to the block. I just had a Briggs that needed 1/2 choke to run. The bolts were loose permitting too much air. Also check that you don't have this situation either!! 1 1 Share this post Link to post Share on other sites
702854boy 1,168 #13 Posted 1 hour ago What happened there? 1 hour ago, ri702bill said: Also check that you don't have this situation either!! Share this post Link to post Share on other sites
ri702bill 13,242 #14 Posted 1 hour ago This is typlical of what I found thruout this C81 - I named it "Good 'nuff" after the PO's attitude to "fixing" things... Share this post Link to post Share on other sites
ri702bill 13,242 #15 Posted 1 hour ago 2 minutes ago, 702854boy said: What happened there? The inattention of the PO ... the only reasons I bought it was that it had a gray, low hours service replacement K181 and I already has a disassembled twin to it minus the engine. Everything that was removed & reassembled to swap it was either done poorly or just flat out butchered. But, it actually ran !! Share this post Link to post Share on other sites
