tallen4392 71 #1 Posted 2 hours ago Good morning my charger 12 has been used for snow removal for the last 7 or 8 years awesome machine all of a sudden it is running better only when the choke is 1/4 open when I open it all the way it starts to run rough never happened before should I remove carb and clean it or try to find a new carb the ones I see look like junk carbs where can I get a original carb ?? Share this post Link to post Share on other sites
ebinmaine 81,002 #2 Posted 2 hours ago Rebuilding your own is a pretty easy thing to do. It's just a matter of taking the time to clean things properly. Not at all complicated. The biggest thing to check for is, make sure the throttle shaft is not too loose in the bore. @76c12091520h Brian Badman may have a rebuilt carb for you. 1 Share this post Link to post Share on other sites
702854boy 1,167 #3 Posted 2 hours ago (edited) It would be better to try to remove the original carb and clean it up since as you said the repops are junk, but if you'd rather buy a carb instead of cleaning, a couple of our vendors here such as K&B Horse Parts @76c12091520h have them for sale Edit: @ebinmaine has faster fingers than me Edited 2 hours ago by 702854boy 1 Share this post Link to post Share on other sites
lynnmor 9,055 #4 Posted 1 hour ago 33 minutes ago, tallen4392 said: YOU should remove carb and clean it 1 Share this post Link to post Share on other sites
peter lena 10,099 #5 Posted 1 hour ago @tallen4392 ever drain out clean ,your fuel tank ? bet you your repetitive problem starts there, years ago did that , then installed a new flow valve , with fuel filter close to tank , been adding an ounce or two of STA BIL , fuel storage additive , to EVERY TANK TOP OFF . also dropped carb bowl , clean out , guess what ? also replaced , old original fuel hoses , NEVER HAD ANOTHER , FUEL DEBRIS ISSUE ! love repetitive issues / problems ? dissect them , make a change , this issue is like , bearing lubrication failure , what could you possibly do ? also killed that years ago , easy stuff , pete Share this post Link to post Share on other sites
ri702bill 13,241 #6 Posted 51 minutes ago (edited) 1 hour ago, tallen4392 said: should I remove carb and clean it Absolutely. The best results are achieved by disassembling the carb, soaking it in an Ultrasonic cleaner - 2 or 3 cycles, and using a quality (Kohler preferred) carb rebuild kit. As @ebinmaine stated, check the throttle shaft and the bushings first for excessive wear. Both are replacable on your carb (unlike the lower HP versions). Then decide if it's keep it or toss it.... Worn bushings & shafts make the engine run too lean, as it makes for a large vacuum leak. DO check the condition of the Main mix needle - it is hollow with a small hole at the top & bottom - those must be kept open, If either are clogged, the main circuit will not be able to be properly adjusted... Edited 47 minutes ago by ri702bill 1 Share this post Link to post Share on other sites
ebinmaine 81,002 #7 Posted 48 minutes ago 2 minutes ago, ri702bill said: quality (Kohler preferred) carb rebuild kit. Kohler has discontinued them 1 Share this post Link to post Share on other sites
ri702bill 13,241 #8 Posted 45 minutes ago Some folks still have them advertised for sale - though they are very proud of them judging by the prices... Share this post Link to post Share on other sites
Ed Kennell 47,692 #9 Posted 23 minutes ago Check the two bolts that hold it to the block. I just had a Briggs that needed 1/2 choke to run. The bolts were loose permitting too much air. Share this post Link to post Share on other sites
