davem1111 2,444 #2 Posted November 4 The lever is supposed to raise the deck more than that, and lock in the "up" position if you want to. I'm guessing that your linkage from the lever arm to the deck needs to be adjusted. There are some chain links in there and it may need to be moved up by one link. It's difficult to get up in there, even with the deck off. Share this post Link to post Share on other sites
davem1111 2,444 #3 Posted November 4 Maybe this picture will help a bit. Share this post Link to post Share on other sites
953 nut 70,344 #4 Posted November 4 There is an adjustment knob next to the lift lever that controls how far down the deck can go. If you turn the knob so all the threads are gone and then attach the chain so there is a little slack it will be better. 2 Share this post Link to post Share on other sites
Bar Nuthin 3,523 #5 Posted November 4 Like @953 nut said, start by backing this knob counterclockwise all the way. You may need to remove the little cap that is protecting the threads. If that doesn't allow the deck (height wheels) to rest completely on the ground, check underneath the tractor to see what is restricting the lift arm from @davem1111's photo Some people secure that lift arm in the up position (with zip-ties or wire) when they attach snowplow blades or blowers. 1 Share this post Link to post Share on other sites
Ed Kennell 47,821 #6 Posted November 4 (edited) That lever on the left is used to lift the deck for transporting. When pulled back and latched, it should lift the deck up till the rubber bumpers on the deck frame contact the tractor floorboards for stable quiet transporting. That lever operates a rock shaft that is connected by a chain to the deck lift arm shown here and in the pictures above. The rod on this lift arm should be in the deck slot as shown below. This lift arm is connected at the rear of the frame in two bushings make sure it is properly connected to the deck and the rear of the tractor.. If everything is connected properly, you probably just need to shorten the chain between the rock shaft and the lift lever. Edited November 4 by Ed Kennell 2 3 Share this post Link to post Share on other sites
Ed Kennell 47,821 #7 Posted November 4 Looks like you have a 42" RD deck. Download the manuals for operating instructions .Mower Rotary 42in RD 1990 05-42RY01 OM TIPL SN.pdf - Mower decks & reel - RedSquare Wheel Horse Forum 2 Share this post Link to post Share on other sites
Ed Kennell 47,821 #8 Posted November 4 (edited) Improper installation of the deck to the attach-a-matic could also affect the lift . Make sure the notched tab on the deck rod is on the proper rod in the attach-a-matic. Edited November 4 by Ed Kennell 1 1 Share this post Link to post Share on other sites
Skwerl58 843 #9 Posted November 4 All of the responses are very good. I have a 414-8 that I struggled with the lift height until I got a copy of the parts schematic that showed which hole the trunion mounts in for different equipment. I have attached a copy of a link of a schematic. I made a copy of a cleaner copy and keep it in the shed: https://www.partstree.com/models/31-14k803-414-8-toro-garden-tractor-1988/manual-lift-linkage-6/ Share this post Link to post Share on other sites
bradleydavidgood 46 #10 Posted November 5 You guys are so helpful! Just amazing this response. Thank you! It may be another week or two until I get back to it. I'm jammed with renovations and electric install. Thanks 1 Share this post Link to post Share on other sites
