Sparky
Popped my first transmission
Sparky
  I know the WH isn’t a bulldozer (no I don’t)
  Just driving around looking at flowers (no I wasn’t)
  So there I was pushing railroad ties with my GT-1600 when it made a weird noise, moved forward another foot and then she went into “infinite neutral mode” . Towed her into the ER and the hubs are good, the trans drive pulley and keyway are good and of course the fluid is clean/full.
  Jack up and it makes some weird and horrible noises when it’s spun. And one time it actually locked up.
  Have a few (4 spares) transmissions here so it’ll get a new trans. Busted one is the original 1” axle unit with 4 pinions. I’ll install a trans with a 1-1/8” axles and 8 pinions.
  • Sad 7
Easton Rich
8 speed are no longer indestructible I take it?
Sparky
  I think I might have been asking to much of it.  I have owned this one for at least 15 years and it’s been worked hard! Never was used for easy leisurely mowing. Always towing and plowing snow dirt and stone (and today it was railroad ties).
  It does have the weaker of the 8 speeds so it’ll be getting an upgrade with the new trans.
ebinmaine
A 4 pinion transmission is VERY different from the heavy duty  8 pinion version.
Easton Rich
Never broke one, but I only have 1, 1" 4 pinion 8spd that doesn't get worked.
wallfish
Something got caught in the gear teeth.
Open it up because you can't break it any more than all ready broke. Interested to know what let go.
  • Like 7
Bill D
While you have the transmission out, check the mounting plate for cracks.
  • Excellent 2
ri702bill
My money is on the differential - as in one or more of the pinions decided enough is enough. You did not drop the plow first before all this? Very optomistic of you!
  • Haha 1
ebinmaine
@Sparky doesn't need to be optimistic. He has several spares.
:handgestures-thumbupright:
Sparky
Haha! Good eye Bill.
  Actually was just running it on jackstands to see what the transmission would do and how it sounded (both were bad). Was hoping to find a sheared key on the drive pulley.
  It’s “plowless” now while it awaits surgery.
953 nut
Gotta open her up just to entertain us, we all need a little tractor porn to start the day.   :wwp:     We want to see Mike up to his elbows in gear oil and parts and pieces.   :ychain:
  • Haha 6
ri702bill
Surgery, no... transplant, yes. A much easier task when dealing with an early one pedal short frame tractor. To switch yours, you will fill a coffee can with fasteners & small parts - not counting the small trophy fiddely-bits inside the Unidrive...
squonk
Gear oil smell wafting into the house! WHO'S WITH ME!!!! :banana-wrench:
  • Haha 7
ri702bill
Ah, yes, the unmistakeable lingering fragrance of 90 weight in the drain pan & on the parts! BT, DT.
peter lena
@Sparky  having a hi / low range set up , quickly lightens the  loading  on the trans , 3 gear  , low range , is an effortless mover  , also  have driven around  and put miles on  high  milage atf  fluid for  flushing, since doing that years ago  , its easy to refresh  your set up , have local  cul de sacs  , for road  gear time , every gear / range , the flush out effects are  very thorough , also  like a climbing gear oil , read specs ,  my shift  boots are all , greased underside , to enhance  slide ability  over irregularities' , like a large tie wrap , at  happy  spot , look for  usage movement . most of my , mods are based on , REPEDITIVE FAILURE , regularly , try anything to improve function . pete
Sparky
  No idea what all that nonsense (and difficult to read I might add) has to do with me swapping a manual transmission out?
  • Like 4
  • Confused 1
  • Heart 2
Sparky
  Had a chance this morning to get back to this rig. Trans is out!
  Fuel line is old and showing cracks in the rubber so that’s also going to be replaced. Drive belt is new so that’s staying.
  The brake band was a new one from Bob @rmaynard and it’s still like new 6 or 7 years later :handgestures-thumbupright:
  Amazingly the tow hitch came right out!
  • Excellent 3
cleat
Oil looks very good so that is not the cause I would think.
Sparky
 No, she was full and there was no water in it.
   I’m sure it was me pushing this 4 pinion- 1” axle unit harder than I should have. And I have been for years! Plus it’s over 40 years old so things happen.
  Blame is all on me, but I’ll go shopping for a new tranny and maybe have it all back together tomorrow :handgestures-thumbupright: ready to get back to work.
squonk
Looks like the " pullstart elves " have paid a visit to your workbench! :ROTF::ychain:
Extra jib points for draining out that gear oil near your house's entrance! :banana-wrench:
Edited by squonk
  • Haha 2
c-series don
When replacing the fuel line I use a double male barbed fitting, connecting the old one to the new one. Then you can pull the old one out and the new one in very easily.
ebinmaine
Single female named Trina.
I don't get dirty and she pops the new one in very easily.
Corrected to my current favorite method.
:lol:
  • Haha 3
squonk
I use my short fiberglass electrical fish rods from Horror Fright.
Dan 312-8
Genius! :handgestures-thumbupright:
