Sparky-(Admin) 26,575 #1 Posted October 30 I know the WH isn’t a bulldozer (no I don’t) Just driving around looking at flowers (no I wasn’t) So there I was pushing railroad ties with my GT-1600 when it made a weird noise, moved forward another foot and then she went into “infinite neutral mode” . Towed her into the ER and the hubs are good, the trans drive pulley and keyway are good and of course the fluid is clean/full. Jack up and it makes some weird and horrible noises when it’s spun. And one time it actually locked up. Have a few (4 spares) transmissions here so it’ll get a new trans. Busted one is the original 1” axle unit with 4 pinions. I’ll install a trans with a 1-1/8” axles and 8 pinions. 1 1 7 Share this post Link to post Share on other sites
Easton Rich 1,272 #2 Posted October 30 8 speed are no longer indestructible I take it? Share this post Link to post Share on other sites
Sparky-(Admin) 26,575 #3 Posted October 30 1 minute ago, Easton Rich said: 8 speed are no longer indestructible I take it? I think I might have been asking to much of it. I have owned this one for at least 15 years and it’s been worked hard! Never was used for easy leisurely mowing. Always towing and plowing snow dirt and stone (and today it was railroad ties). It does have the weaker of the 8 speeds so it’ll be getting an upgrade with the new trans. 3 1 Share this post Link to post Share on other sites
ebinmaine 81,003 #4 Posted October 31 2 hours ago, Easton Rich said: 8 speed are no longer indestructible I take it? A 4 pinion transmission is VERY different from the heavy duty 8 pinion version. 1 1 Share this post Link to post Share on other sites
Easton Rich 1,272 #5 Posted October 31 Never broke one, but I only have 1, 1" 4 pinion 8spd that doesn't get worked. 1 Share this post Link to post Share on other sites
wallfish 20,705 #6 Posted October 31 4 hours ago, Sparky said: And one time it actually locked up. Something got caught in the gear teeth. Open it up because you can't break it any more than all ready broke. Interested to know what let go. 7 1 Share this post Link to post Share on other sites
Bill D 3,177 #7 Posted October 31 While you have the transmission out, check the mounting plate for cracks. 3 2 Share this post Link to post Share on other sites
ri702bill 13,242 #8 Posted October 31 My money is on the differential - as in one or more of the pinions decided enough is enough. You did not drop the plow first before all this? Very optomistic of you! 1 1 Share this post Link to post Share on other sites
ebinmaine 81,003 #9 Posted October 31 1 hour ago, ri702bill said: Very optomistic of you! @Sparky doesn't need to be optimistic. He has several spares. Share this post Link to post Share on other sites
Sparky-(Admin) 26,575 #10 Posted October 31 1 hour ago, ri702bill said: My money is on the differential - as in one or more of the pinions decided enough is enough. You did not drop the plow first before all this? Very optomistic of you! Haha! Good eye Bill. Actually was just running it on jackstands to see what the transmission would do and how it sounded (both were bad). Was hoping to find a sheared key on the drive pulley. It’s “plowless” now while it awaits surgery. 1 1 Share this post Link to post Share on other sites
953 nut 69,932 #11 Posted October 31 1 hour ago, Sparky said: It’s “plowless” now while it awaits surgery. 1 hour ago, ebinmaine said: He has several spares. Gotta open her up just to entertain us, we all need a little tractor porn to start the day. We want to see Mike up to his elbows in gear oil and parts and pieces. 2 6 Share this post Link to post Share on other sites
ri702bill 13,242 #12 Posted October 31 2 hours ago, Sparky said: It’s “plowless” now while it awaits surgery. Surgery, no... transplant, yes. A much easier task when dealing with an early one pedal short frame tractor. To switch yours, you will fill a coffee can with fasteners & small parts - not counting the small trophy fiddely-bits inside the Unidrive... 1 Share this post Link to post Share on other sites
squonk 48,250 #13 Posted October 31 Gear oil smell wafting into the house! WHO'S WITH ME!!!! 1 6 Share this post Link to post Share on other sites
ri702bill 13,242 #14 Posted October 31 6 minutes ago, squonk said: Gear oil smell wafting into the house! WHO'S WITH ME!!!! Ah, yes, the unmistakeable lingering fragrance of 90 weight in the drain pan & on the parts! BT, DT. 3 Share this post Link to post Share on other sites
peter lena 10,099 #15 Posted October 31 @Sparky having a hi / low range set up , quickly lightens the loading on the trans , 3 gear , low range , is an effortless mover , also have driven around and put miles on high milage atf fluid for flushing, since doing that years ago , its easy to refresh your set up , have local cul de sacs , for road gear time , every gear / range , the flush out effects are very thorough , also like a climbing gear oil , read specs , my shift boots are all , greased underside , to enhance slide ability over irregularities' , like a large tie wrap , at happy spot , look for usage movement . most of my , mods are based on , REPEDITIVE FAILURE , regularly , try anything to improve function . pete 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,575 #16 Posted October 31 2 hours ago, peter lena said: @Sparky having a hi / low range set up , quickly lightens the loading on the trans , 3 gear , low range , is an effortless mover , also have driven around and put miles on high milage atf fluid for flushing, since doing that years ago , its easy to refresh your set up , have local cul de sacs , for road gear time , every gear / range , the flush out effects are very thorough , also like a climbing gear oil , read specs , my shift boots are all , greased underside , to enhance slide ability over irregularities' , like a large tie wrap , at happy spot , look for usage movement . most of my , mods are based on , REPEDITIVE FAILURE , regularly , try anything to improve function . pete No idea what all that nonsense (and difficult to read I might add) has to do with me swapping a manual transmission out? 4 1 1 2 Share this post Link to post Share on other sites
Sparky-(Admin) 26,575 #17 Posted 3 hours ago Had a chance this morning to get back to this rig. Trans is out! Fuel line is old and showing cracks in the rubber so that’s also going to be replaced. Drive belt is new so that’s staying. The brake band was a new one from Bob @rmaynard and it’s still like new 6 or 7 years later Amazingly the tow hitch came right out! 2 Share this post Link to post Share on other sites
cleat 9,390 #18 Posted 1 hour ago Oil looks very good so that is not the cause I would think. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,575 #19 Posted 1 hour ago 25 minutes ago, cleat said: Oil looks very good so that is not the cause I would think. No, she was full and there was no water in it. I’m sure it was me pushing this 4 pinion- 1” axle unit harder than I should have. And I have been for years! Plus it’s over 40 years old so things happen. Blame is all on me, but I’ll go shopping for a new tranny and maybe have it all back together tomorrow ready to get back to work. 1 Share this post Link to post Share on other sites
