Skwerl58
Fixing fuel issue
sqrlgtr
1 hour ago, Skwerl58 said:
I have been having fuel issues with my 1054. I have changed the fuel pump to electric and have  not gotten over a year out of three different Amazon pumps. I ordered a Facet pump and installed it and also changed my fuel line, fuel filter and removed the sediment bowl. The sediment bowl would catch some trash in the tube and not allow fuel into the bowl at times. I rode it today for about 10 minutes and the  issues are gone, runs great, starts quickly and not starving for gas. I think this new setup has taken care of the fuel issues.
I just ordered a Carbole pump from the jungle and hope thats not one of the pumps you had trouble with :unsure:. Have 2 of the Facet pumps and have had no problems so far just thought I would try one of the Carbole pumps this time because everyone said they have had good luck with them and they are half what the Facets fetch.
oldlineman
My experience is that with almost anything, you can buy a good (more expensive item) once or or a cheaper item several times, both seem in the end too cost the same!  :unsure:
  • Thanks 2
ri702bill
Electric fuel pumps require clean gasoline to work well - some type of decent filter is required between the tank and the pump. A coarse screen button style is not the proper choice...
  • Excellent 3
ebinmaine
Agreed. Value is not just financial.
ri702bill
Posted (edited)
For me, it comes down to 2 factors - the price difference between the so-so and the better procucts - and the biggie - the PITA factor. How difficult is it to change out?
The axle seals on a Unidrive are a good example. Short change in price, but can be a chore to get the hub off. I always use a top quality brand for that.
Do it once, do it right.....
Edited by ri702bill
  • Excellent 5
sqrlgtr
Yeah, I'm in the buy once cry once camp on most things, but the Carbole fuel pumps get some good praise on here so thought I would give them a try.
Ed Kennell
I tried a couple $10  pimps.  They both died the first season.     Now have the $30 Carbole pumps on three tractors for several years with no problems.
I mount them as low as possible and have good filters before the pumps.  Also remove the in tank screens from the petcocks.  Do not let the e-pumps run dry.
  • Like 4
  • Excellent 2
sqrlgtr
Them $10 pimps will get ya in trouble :ychain:
  • Haha 5
squonk
I had issues with 953. Very fine rust particles would clog the outlet fitting. I placed a magnet in the tank and any fine rust particles flow to that.
ebinmaine
How do we feel about having a filter before n after the fuel pump?
953 nut
Personal preference is filter after the pump. no reason, just what I usually do.          :confusion-confused:           Now that I think of it I have a couple with the filter before the pump.
  • Haha 2
squonk
Filter before the pump. Grit can destroy an electric pump.
  • Like 5
Ed Kennell
Yep, Why not have clean fuel in the pump and carb?
  • Like 4
Skwerl58
Squonk's idea of a magnet in the tank for the fine rust is a good idea. That is what clogged the sediment bowl up.
peter lena
@Skwerl58  have carbole pumps for years , bombproof , that said , never do a  PARTIAL / CHANGE / IMPROVEMENT , totally  cleaned out tank , new petcock , valve , dielectric grease on related grommets , makes for very easy , swap , have a  filter   immediately , at fuel start . have a fuel filter and a  check valve /  clear hose up to  carb , so I can see clear  standing  fuel , also add  1 to 2  ounces of STA BIL to EVERY TANK TOP OFF . GUESS WHAT ?  YEARS IN ON THIS , NO  FUEL FILTER  DEBRIS OF ANY KIND , carb bowls are  clean / clear , same set up on stand by gen , instant starts , and no debris . once verified for  solid usage , MAINTAIN WHAT GOT ME THERE !  that's my road test  ,  that a regular for me , love killing chronic issues , pete
