Skwerl58 843 #1 Posted October 7 I have been having fuel issues with my 1054. I have changed the fuel pump to electric and have not gotten over a year out of three different Amazon pumps. I ordered a Facet pump and installed it and also changed my fuel line, fuel filter and removed the sediment bowl. The sediment bowl would catch some trash in the tube and not allow fuel into the bowl at times. I rode it today for about 10 minutes and the issues are gone, runs great, starts quickly and not starving for gas. I think this new setup has taken care of the fuel issues. 2 8 Share this post Link to post Share on other sites
sqrlgtr 4,224 #2 Posted October 7 1 hour ago, Skwerl58 said: I have been having fuel issues with my 1054. I have changed the fuel pump to electric and have not gotten over a year out of three different Amazon pumps. I ordered a Facet pump and installed it and also changed my fuel line, fuel filter and removed the sediment bowl. The sediment bowl would catch some trash in the tube and not allow fuel into the bowl at times. I rode it today for about 10 minutes and the issues are gone, runs great, starts quickly and not starving for gas. I think this new setup has taken care of the fuel issues. I just ordered a Carbole pump from the jungle and hope thats not one of the pumps you had trouble with . Have 2 of the Facet pumps and have had no problems so far just thought I would try one of the Carbole pumps this time because everyone said they have had good luck with them and they are half what the Facets fetch. Share this post Link to post Share on other sites
oldlineman 1,821 #3 Posted October 7 My experience is that with almost anything, you can buy a good (more expensive item) once or or a cheaper item several times, both seem in the end too cost the same! 1 2 Share this post Link to post Share on other sites
ri702bill 13,389 #4 Posted October 7 Electric fuel pumps require clean gasoline to work well - some type of decent filter is required between the tank and the pump. A coarse screen button style is not the proper choice... 2 3 Share this post Link to post Share on other sites
ebinmaine 81,273 #5 Posted October 7 1 hour ago, oldlineman said: My experience is that with almost anything, you can buy a good (more expensive item) once or or a cheaper item several times, both seem in the end too cost the same! Agreed. Value is not just financial. 3 Share this post Link to post Share on other sites
ri702bill 13,389 #6 Posted October 7 (edited) 3 hours ago, oldlineman said: My experience is that with almost anything, you can buy a good (more expensive item) once or or a cheaper item several times, both seem in the end too cost the same! For me, it comes down to 2 factors - the price difference between the so-so and the better procucts - and the biggie - the PITA factor. How difficult is it to change out? The axle seals on a Unidrive are a good example. Short change in price, but can be a chore to get the hub off. I always use a top quality brand for that. Do it once, do it right..... Edited October 7 by ri702bill 1 5 Share this post Link to post Share on other sites
sqrlgtr 4,224 #7 Posted October 7 4 hours ago, oldlineman said: My experience is that with almost anything, you can buy a good (more expensive item) once or or a cheaper item several times, both seem in the end too cost the same! 3 hours ago, ebinmaine said: Agreed. Value is not just financial. 1 hour ago, ri702bill said: For me, it comes down to 2 factors - the price difference between the so-so and the better procucts - and the biggie - the PITA factor. How difficult is it to change out? The axle seals on a Unidrive are a good example. Short change in price, but can be a chore to get the hub off. I always use a top quality brand for that. Do it once, do it right..... Yeah, I'm in the buy once cry once camp on most things, but the Carbole fuel pumps get some good praise on here so thought I would give them a try. 2 1 Share this post Link to post Share on other sites
Ed Kennell 47,936 #8 Posted October 7 I tried a couple $10 pimps. They both died the first season. Now have the $30 Carbole pumps on three tractors for several years with no problems. I mount them as low as possible and have good filters before the pumps. Also remove the in tank screens from the petcocks. Do not let the e-pumps run dry. 4 2 Share this post Link to post Share on other sites
sqrlgtr 4,224 #9 Posted October 7 1 hour ago, Ed Kennell said: I tried a couple $10 pimps. Them $10 pimps will get ya in trouble 1 5 Share this post Link to post Share on other sites
squonk 48,426 #10 Posted October 7 I had issues with 953. Very fine rust particles would clog the outlet fitting. I placed a magnet in the tank and any fine rust particles flow to that. 3 1 Share this post Link to post Share on other sites
ebinmaine 81,273 #11 Posted October 7 16 minutes ago, squonk said: I had issues with 953. Very fine rust particles would clog the outlet fitting. I placed a magnet in the tank and any fine rust particles flow to that. How do we feel about having a filter before n after the fuel pump? 1 Share this post Link to post Share on other sites
953 nut 70,647 #12 Posted October 7 Personal preference is filter after the pump. no reason, just what I usually do. Now that I think of it I have a couple with the filter before the pump. 2 2 Share this post Link to post Share on other sites
squonk 48,426 #13 Posted October 8 Filter before the pump. Grit can destroy an electric pump. 5 Share this post Link to post Share on other sites
Ed Kennell 47,936 #14 Posted October 8 10 minutes ago, squonk said: Filter before the pump. Grit can destroy an electric pump. Yep, Why not have clean fuel in the pump and carb? 4 Share this post Link to post Share on other sites
Skwerl58 843 #15 Posted October 8 Squonk's idea of a magnet in the tank for the fine rust is a good idea. That is what clogged the sediment bowl up. 2 Share this post Link to post Share on other sites
peter lena 10,123 #16 Posted October 8 @Skwerl58 have carbole pumps for years , bombproof , that said , never do a PARTIAL / CHANGE / IMPROVEMENT , totally cleaned out tank , new petcock , valve , dielectric grease on related grommets , makes for very easy , swap , have a filter immediately , at fuel start . have a fuel filter and a check valve / clear hose up to carb , so I can see clear standing fuel , also add 1 to 2 ounces of STA BIL to EVERY TANK TOP OFF . GUESS WHAT ? YEARS IN ON THIS , NO FUEL FILTER DEBRIS OF ANY KIND , carb bowls are clean / clear , same set up on stand by gen , instant starts , and no debris . once verified for solid usage , MAINTAIN WHAT GOT ME THERE ! that's my road test , that a regular for me , love killing chronic issues , pete 2 Share this post Link to post Share on other sites
