Skwerl58
Fixing fuel issue
Skwerl58
I have been having fuel issues with my 1054. I have changed the fuel pump to electric and have  not gotten over a year out of three different Amazon pumps. I ordered a Facet pump and installed it and also changed my fuel line, fuel filter and removed the sediment bowl. The sediment bowl would catch some trash in the tube and not allow fuel into the bowl at times. I rode it today for about 10 minutes and the  issues are gone, runs great, starts quickly and not starving for gas. I think this new setup has taken care of the fuel issues.
  • Excellent 7
sqrlgtr
I just ordered a Carbole pump from the jungle and hope thats not one of the pumps you had trouble with :unsure:. Have 2 of the Facet pumps and have had no problems so far just thought I would try one of the Carbole pumps this time because everyone said they have had good luck with them and they are half what the Facets fetch.
oldlineman
My experience is that with almost anything, you can buy a good (more expensive item) once or or a cheaper item several times, both seem in the end too cost the same!  :unsure:
ri702bill
Electric fuel pumps require clean gasoline to work well - some type of decent filter is required between the tank and the pump. A coarse screen button style is not the proper choice...
  • Excellent 3
ebinmaine
Agreed. Value is not just financial.
ri702bill
For me, it comes down to 2 factors - the price difference between the so-so and the better procucts - and the biggie - the PITA factor. How difficult is it to change out?
The axle seals on a Unidrive are a good example. Short change in price, but can be a chore to get the hub off. I always use a top quality brand for that.
Do it once, do it right.....
Edited by ri702bill
  • Excellent 5
sqrlgtr
Yeah, I'm in the buy once cry once camp on most things, but the Carbole fuel pumps get some good praise on here so thought I would give them a try.
Ed Kennell
I tried a couple $10  pimps.  They both died the first season.     Now have the $30 Carbole pumps on three tractors for several years with no problems.
I mount them as low as possible and have good filters before the pumps.  Also remove the in tank screens from the petcocks.  Do not let the e-pumps run dry.
sqrlgtr
Them $10 pimps will get ya in trouble :ychain:
