ebinmaine
Camper cover building construction thread
SylvanLakeWH
Any guess on what $$$ you'll have into it?
I'm always thinking of doing a shed and your approach intrigues me - subject to cost of course...
rjg854
On 11/22/2026 at 4:28 PM, ebinmaine said:
I haven't seen standing seam steel screwed down like that before :confusion-scratchheadyellow:
ebinmaine
That's addressed in post #46
ebinmaine
The original kit was $1400. That's the metal frame structure and the inexpensive sheet metal to cover the roof and a small part of the sides.
We chose to use much better sheet metal for the roof and of course finish covering all 4 sides.  The corrugated sheet metal could be had for $1500 ish?
Back wall framing. Front door framing.
Storm door for the back wall.
PT base. Hardware, etc... another $1000?
All told - at retail prices - you could easily buy all the parts for well under $4000.
A wooden stud building would definitely be stronger... and also about 4 times the price around here.
If you don't need the high wall height, a regular carport kit would be less.
ebinmaine
The back wall is finished except the small spot over the door. That'll get done with the door installation.
The roof panels are all on.
I have a piece of 90⁰ trim to install over the back corner.
SylvanLakeWH
Lookin' good!!!
:eusa-clap:
Looks big enough to store, uhm... what was that tractor :confusion-confused:... it's been a few minutes since last we heard... anything... :techie-hourglass:
oh yeah... Colossus...?
:ychain:
