ebinmaine 80,988 #26 Posted Saturday at 09:33 PM 2 hours ago, Handy Don said: Force field If ONLY that was an option. 2 hours ago, Handy Don said: Consider bifolds (or even accordian) to keep as much weight as possible directly supported vertically by the hinge/pivot and not trying to deform the frame when the door is open? The folding doors are the most likely direction I was headed. Opening is 14 ish feet wide so I figure to make a pair of 4 footers against the outside and 3 footers for the middle. They'll be quite tall. Somewhat gangly. But usable. Share this post Link to post Share on other sites
ebinmaine 80,988 #27 Posted Saturday at 09:33 PM Here's the beginnings of the PT base. 3 Share this post Link to post Share on other sites
grinchsr 675 #28 Posted yesterday at 01:34 AM Now you have to fill it that’s the fun part 1 Share this post Link to post Share on other sites
ebinmaine 80,988 #29 Posted yesterday at 01:36 AM 1 minute ago, grinchsr said: Now you have to fill it that’s the fun part Plenty of machines here to live in there with the camper. Share this post Link to post Share on other sites
ebinmaine 80,988 #30 Posted 17 hours ago PT base is done. We took measurements front middle and rear yesterday afternoon at the top of the legs. Front was 14' 2". Rear 14' 1". I decided to make the whole frame 14' 1" for consistency. The PT base is cut to 14' 5" across by 20' and 1/2". The extra width gives the metal a centered set on the 5 1/2" wide PT boards. I measured the PT base for square. Metal frame attached to the PT base. These are 5/16" x 2 1/2" grade 5 lag bolts we had in stock. I broke the last one so I'll drill the metal base and add another bolt later. The frame is flush to the front of the base and nearly centered on the back. I did that because nearly the whole front will be big doors. Started a few anchors in but discovered my medium strength 1/2" impact wrench isn't strong enough. It has a spec of 400 ft lbs maximum driving force. I've ordered the heavy duty version which is over twice that strength at 900 ft lbs! Soooooo upset I hadda order more tools. I also ordered some cargo straps which will be fastened from the lower anchors to a point on the metal frame. 10 anchors. 10 straps. 2 Share this post Link to post Share on other sites
Handy Don 17,581 #31 Posted 16 hours ago 18 minutes ago, ebinmaine said: medium strength 1/2" impact ... isn't strong enough Not wanting to be a wet blanket and seem like I’m discouraging tool acquisitions, but sometimes a rental tool makes sense when there is low likelihood of future use. 1 Share this post Link to post Share on other sites
ebinmaine 80,988 #32 Posted 16 hours ago 20 minutes ago, Handy Don said: Not wanting to be a wet blanket and seem like I’m discouraging tool acquisitions, but sometimes a rental tool makes sense when there is low likelihood of future use. Absolutely agreed and I thought through this one. With the increasing forays into heavier machine repair (like my truck or the backhoe or splitter) and the occasional need I've already had in the past for a stronger impact tool, this makes sense for us at this point in time. 2 Share this post Link to post Share on other sites
953 nut 69,856 #33 Posted 2 hours ago On 10/31/2026 at 1:34 PM, ebinmaine said: The front wall will basically be a whole door as noted in a post above. Most likely a light duty wood frame with sheets of very thin Advantech. I'm definitely open to other ideas and suggestions there. Have you considered fiberglass? When I worked as a farm manager at a hydroponic greenhouse we built doors and sheds with a clear fiberglass sheeting exterior. https://www.gothicarchgreenhouses.com/fiberglass-rolls Rolls are 4' wide and 50' long 1 1 Share this post Link to post Share on other sites
ebinmaine 80,988 #34 Posted 39 minutes ago 2 hours ago, 953 nut said: considered fiberglass I have. Definitely a possibility. I really like the light weight. ... The issue there is puncture resistance. Share this post Link to post Share on other sites
