rick 318 #1 Posted September 30 I installed a Fumoto valve in my M14 Kohler to make oil drains easier. To drain the oil in my 314-8, I had to remove the deck or use a Mityvac vacuum evacuator. Any other methods would end up in a mess with oil spilled some where. Given enough rain and sunshine I cut every 4-5 days in the growing season for 3+ hours a tour. 25 hour services roll around quickly. The Fumoto valve has a nipple that a 3/8 soft clear tube plugs onto to direct the flow of waste oil to a drain pan. No more bending license plates and trying to work around obsructions or trying to get the the vacuum hose past the tube and into the crankcase of the Magnum engine. 3 2 Share this post Link to post Share on other sites
ri702bill 13,116 #2 Posted September 30 Pictures?? I ask because of the added length... does it get in the way of anything? Share this post Link to post Share on other sites
WHX?? 58,254 #3 Posted September 30 For those of you who don't know what they are. https://www.fumotousa.com/ Not exactly giving them away but if you need to change your oil a lot ... priceless. 2 1 Share this post Link to post Share on other sites
ebinmaine 80,807 #4 Posted September 30 2 hours ago, WHX?? said: For those of you who don't know what they are. https://www.fumotousa.com/ Not exactly giving them away but if you need to change your oil a lot ... priceless. The value of the item exceeds monetary considerations. 2 1 Share this post Link to post Share on other sites
953 nut 69,633 #5 Posted September 30 I just screwed a 3/8 NPT ball valve into the drain outlet and come oil change time you can screw a hose with a fitting into the other end and no mess. Valves are about five bucks and you use the same hose for all of them. 1 Share this post Link to post Share on other sites
WHX?? 58,254 #6 Posted September 30 40 minutes ago, 953 nut said: 3/8 NPT ball valve All fine and dandy until a stick ... which you should have picked up before ... jumps up and opens the valve and decides to oil the deck. Luckily you saw it happen in time. So then you remove the handle and promptly forget where you put it at oil change time. Since SWMBO isn't around 953nut gets the blame ... 4 Share this post Link to post Share on other sites
Racinbob 13,200 #7 Posted October 1 Got them on about everything that gets the oil changed. No, not cheap but worth every penny to me. 3 Share this post Link to post Share on other sites
squonk 48,180 #8 Posted October 1 (edited) 32 minutes ago, Racinbob said: Got them on about everything that gets the oil changed. No, not cheap but worth every penny to me. Yup same here. Edited October 1 by squonk Share this post Link to post Share on other sites
Mike'sHorseBarn 3,683 #9 Posted October 1 Now fellas you've all educated me today! I've never seen this before! Is the one you're using? https://www.fumotousa.com/f106sx.html Share this post Link to post Share on other sites
squonk 48,180 #10 Posted October 1 1 hour ago, Mike'sHorseBarn said: Now fellas you've all educated me today! I've never seen this before! Is the one you're using? https://www.fumotousa.com/f106sx.html Not that one. It's Metric thread. this is the one I use with a hose end https://ezoildrainvalve.com/product/ez-oil-drain-valve-ez-102-pf-38-thread-size https://ezoildrainvalve.com/product/ez-h-001-small-hose-end 1 Share this post Link to post Share on other sites
rick 318 #11 Posted October 1 23 hours ago, ri702bill said: Pictures?? I ask because of the added length... does it get in the way of anything? No pics, no idea how to do it here! The # F110N valve is not in the way of anything on my installation, an M14 Kohler on a 1997 314-8. The belts are out of the way. The valve sticks out a little less than the PTO hoop lower bracket. It's an easy reach to the valve. I would urge you to visit the website fumotousa.com and check the product out. Share this post Link to post Share on other sites
squonk 48,180 #12 Posted October 1 (edited) On 9/30/2026 at 2:01 PM, ri702bill said: Pictures?? I ask because of the added length... does it get in the way of anything? This is how I put them on the small block short framers to clear the clutch pedal. I can leave a deck on and use a hose so I don't get oil all over the deck. On my C-160 it comes out straight and again a hose end and hose to keep the deck clean. Edited October 1 by squonk 1 Share this post Link to post Share on other sites
sqrlgtr 4,032 #13 Posted October 1 @squonk stupid ? but what size did you have to order? I cant remeber for the life of me what size pipe thread WH used. Stinks getting older. Share this post Link to post Share on other sites
squonk 48,180 #14 Posted October 1 15 minutes ago, sqrlgtr said: @squonk stupid ? but what size did you have to order? I cant remeber for the life of me what size pipe thread WH used. Stinks getting older. Click on my link. Gives the part no. 3/8" 1 1 Share this post Link to post Share on other sites
John c 224 #15 Posted 1 hour ago (edited) All fine and dandy until a stick ... which you should have picked up before ... jumps up and opens the valve and decides to oil the deck A short nipple with a cap or a plug in the valve body will prevent that, swap the cap/plug for a hose barb to drain it......but now you've got to keep up with the hose barb, so you can have a choice lose the valve handle, or the hose barb Edited 1 hour ago by John c 1 Share this post Link to post Share on other sites
peter lena 10,079 #16 Posted 1 hour ago @Johnc REPEDITIVE PROBLEMS , SHOW YOU THE WAY TO CHANGE ! they are always there , easy to visualise after valve drainage set up , when I make a change , paint it RED / BLACK , IT DISSAPPERRS , also been using valvoline VR-1 10-30 oil , the difference in operational running ease is amazing , always trying something , good talkin , pete Share this post Link to post Share on other sites
