rick 311 #1 Posted 3 hours ago I installed a Fumoto valve in my M14 Kohler to make oil drains easier. To drain the oil in my 314-8, I had to remove the deck or use a Mityvac vacuum evacuator. Any other methods would end up in a mess with oil spilled some where. Given enough rain and sunshine I cut every 4-5 days in the growing season for 3+ hours a tour. 25 hour services roll around quickly. The Fumoto valve has a nipple that a 3/8 soft clear tube plugs onto to direct the flow of waste oil to a drain pan. No more bending license plates and trying to work around obsructions or trying to get the the vacuum hose past the tube and into the crankcase of the Magnum engine. 1 Share this post Link to post Share on other sites
ri702bill 12,965 #2 Posted 3 hours ago Pictures?? I ask because of the added length... does it get in the way of anything? Share this post Link to post Share on other sites
WHX?? 58,027 #3 Posted 3 hours ago For those of you who don't know what they are. https://www.fumotousa.com/ Not exactly giving them away but if you need to change your oil a lot ... priceless. 2 1 Share this post Link to post Share on other sites
ebinmaine 80,513 #4 Posted 1 hour ago 2 hours ago, WHX?? said: For those of you who don't know what they are. https://www.fumotousa.com/ Not exactly giving them away but if you need to change your oil a lot ... priceless. The value of the item exceeds monetary considerations. 1 Share this post Link to post Share on other sites
