BPEisenhower 578 #1 Posted Saturday at 10:37 PM Hello all! After much debating, I'm going to give the C195 a workout.....with snowthrower. However, it's from that 520H and want to know if its going to work with my C195.. (fingers crossed). 1 Share this post Link to post Share on other sites
wallfish 20,570 #2 Posted Saturday at 11:46 PM Yes, it will work. Weights and chains make better traction. I even use #40 roller chain wrapped around the fronts for much better steering. Adjust the ground speed as necessary to keep it loaded up and keep it from clogging 3 2 Share this post Link to post Share on other sites
ri702bill 12,943 #3 Posted Sunday at 11:13 AM And a quick spray down on the auger & chute with your favorite slick stuff in a can before the storm helps. I find the cheapo store brand cooking spray works fine - just don't leave the can outside in the cold! 1 Share this post Link to post Share on other sites
BPEisenhower 578 #4 Posted Sunday at 08:22 PM 20 hours ago, wallfish said: Yes, it will work. Weights and chains make better traction. I even use #40 roller chain wrapped around the fronts for much better steering. Adjust the ground speed as necessary to keep it loaded up and keep it from clogging And so, I got it attached to the front of my C195 and now another problem, the lifting rod that slides in and out of the tube, where does it pin to? Plus, the drive belt needs to be changed, too short. Not sure how it went on a 520 but it's a pain... Share this post Link to post Share on other sites
wallfish 20,570 #5 Posted Sunday at 08:33 PM The flag pins to the bellcrank. you can find the manual in the manuals section Share this post Link to post Share on other sites
BPEisenhower 578 #6 Posted Sunday at 11:19 PM (edited) 2 hours ago, wallfish said: The flag pins to the bellcrank. you can find the manual in the manuals section Edited Sunday at 11:21 PM by BPEisenhower 1 Share this post Link to post Share on other sites
BPEisenhower 578 #7 Posted Sunday at 11:21 PM First time the belt tensioner/ mule drive has ever been off this tractor 😜. Share this post Link to post Share on other sites
wallfish 20,570 #8 Posted Sunday at 11:40 PM 17 minutes ago, BPEisenhower said: You'll need to add some 3/4" ID spacers to that flag rod if it doesn't lift enough. You want to leave enough play in it to slide in and out so the blower can float up and down a bit when blowing 1 Share this post Link to post Share on other sites
BPEisenhower 578 #9 Posted 6 hours ago 23 hours ago, wallfish said: You'll need to add some 3/4" ID spacers to that flag rod if it doesn't lift enough. You want to leave enough play in it to slide in and out so the blower can float up and down a bit when blowing Unfortunately, I can't figure out how to get it to lift. Tired of wasting time. Anyone close to me can have this thrower for free Share this post Link to post Share on other sites
c-series don 12,402 #10 Posted 5 hours ago If there’s not already holes in the lift flag drill one where the black arrow is pointing and put a hairpin cotter pin in the hole. It may require adding some washers or drilling another hole for proper adjustment. Share this post Link to post Share on other sites
lynnmor 9,029 #11 Posted 3 hours ago On 9/27/2026 at 7:19 PM, BPEisenhower said: That flag pins way up in there, I have no idea what is hanging down there where you pinned. Share this post Link to post Share on other sites
c-series don 12,402 #12 Posted 2 hours ago @lynnmor I agree but I thought that piece sticking down was part of the rockshaft, but I’m not familiar with the underside of a C-195. Share this post Link to post Share on other sites
