cleat 9,441 #1 Posted September 26 2 ton mini split heat pump installation complete in the shop. Drain pipe done, I might shorten it a bit. 3 3 Share this post Link to post Share on other sites
cleat 9,441 #2 Posted September 26 (edited) Shop backup 5000 watt heater just to keep the shop from freezing if the heat pump fails or can't keep up. ++ I wired in a thermostat for more accurate temp control than the control built into the heater. Edited September 26 by cleat 4 1 Share this post Link to post Share on other sites
cleat 9,441 #3 Posted September 26 2 ton heat pump house inside complete with air handler that has backup electric heat coils (hopefully they never need to be used). 2 ton heat pump house outside unit nearly complete. It just needs the line sets to be full wrapped for appearance and to be sealed where they pass into the house. 3 1 Share this post Link to post Share on other sites
ebinmaine 81,274 #4 Posted September 26 @cleat Temp and humidity controls. Share this post Link to post Share on other sites
