FLtractor 205 #1 Posted Thursday at 11:05 PM Evening, are these all the parts I’d need to convert K181 856 electric to Pullstart? Ones I’ve circled- shroud, magneto-pull cup 1 Share this post Link to post Share on other sites
953 nut 68,930 #2 Posted Thursday at 11:15 PM I don't see a backing plate wit a magneto mounted to it. 2 Share this post Link to post Share on other sites
C-85 820 #3 Posted Thursday at 11:24 PM When I saw this post I thought this must be to add a rewind starter, looks like you're going real old style C-85 Share this post Link to post Share on other sites
ebinmaine 80,488 #4 Posted Thursday at 11:29 PM Those look more like Tecumseh engines... The head bolts are through the upper plate and the gas tank bracket is angled odd. Mebbe not. But you'll need a fair amount of parts $$$ to change from a Starter/Generator engine to a pull start. And the labor.... 1 Share this post Link to post Share on other sites
adsm08 5,078 #5 Posted Thursday at 11:57 PM (edited) The particular parts pictured are not for a pull-start, they are for a gear-drive starter. That setup will only work in your tractor if you relocate the battery (see @Thegearhead0324's 1267 thread). You will find on the short-frame units that a gear drive starter and the battery will attempt to occupy some of the same space, and Newtonian physics generally disallows this. Edited Thursday at 11:58 PM by adsm08 1 1 Share this post Link to post Share on other sites
8ntruck 9,256 #6 Posted Friday at 12:21 AM 19 minutes ago, adsm08 said: Newtonian physics generally disallows this. True, but quantum theory says that this would be statistically possible - the probability of it happening make the probability of winning the Powerball seem actually encouraging. 1 1 Share this post Link to post Share on other sites
adsm08 5,078 #7 Posted Friday at 01:04 AM 41 minutes ago, 8ntruck said: True, but quantum theory says that this would be statistically possible - the probability of it happening make the probability of winning the Powerball seem actually encouraging. We are dealing with batteries and starters. Objects at this scale and density tend to adhere to more Newtonian properties, and are generally not subject to the laws described by quantum physics. Share this post Link to post Share on other sites
wallfish 20,563 #8 Posted Friday at 01:07 AM 1 hour ago, adsm08 said: The particular parts pictured are not for a pull-start, they are for a gear-drive starter. That setup will only work in your tractor if you relocate the battery (see @Thegearhead0324's 1267 thread). You will find on the short-frame units that a gear drive starter and the battery will attempt to occupy some of the same space, and Newtonian physics generally disallows this. But there wouldn't be a gear drive starter there to occupy that space and he won't need a battery either since he wants to convert it to pull start. A battery would be needed to continue with using a battery ignition but even then, it could stay put in the tray. No physics necessary Share this post Link to post Share on other sites
adsm08 5,078 #9 Posted Friday at 01:11 AM 2 minutes ago, wallfish said: But there wouldn't be a gear drive starter there to occupy that space and he won't need a battery either since he wants to convert it to pull start. A battery would be needed to continue with using a battery ignition but even then, it could stay put in the tray. No physics necessary I understand all that. However if you look at the parts he circled in the picture he posted, those particular parts are for a gear-drive starter. The flywheel has teeth, the engine shroud has a starter drop, and the screen technically has a pulley you could wrap a rope around, put it is not a true pull-start recoil setup. Share this post Link to post Share on other sites
wallfish 20,563 #10 Posted Friday at 01:19 AM 1 minute ago, adsm08 said: I understand all that. However if you look at the parts he circled in the picture he posted, those particular parts are for a gear-drive starter. The flywheel has teeth, the engine shroud has a starter drop, and the screen technically has a pulley you could wrap a rope around, put it is not a true pull-start recoil setup. Those parts on an engine with the magneto ignition on it can still be used as a pull start only engine. No starter, no battery, no physics. I was going by the title and his question. The only mistake he made was calling the flywheel a magneto. There are some engines with gear starter that have magneto ignition that do not need the starter or a battery to run. They can still do it even though it has a ring gear and bump out on the shroud for a starter 1 Share this post Link to post Share on other sites
702854boy 1,132 #11 Posted Friday at 02:07 AM The engine in the front of the photo looks like a tecky like @ebinmaine stated, it does not have to fuel pump area and the same breather as the kohlers. The engine in the back does however look like a kohler 2 Share this post Link to post Share on other sites
pfrederi 21,103 #12 Posted Friday at 12:51 PM Techy throttle linkage hook up on front engine 1 Share this post Link to post Share on other sites
702854boy 1,132 #13 Posted Friday at 01:21 PM At a second look, they both are techys because the back one has the carb hole and the exhaust hole on the front of the engine instead of the exhaust being on the side like a small block Kohler 1 Share this post Link to post Share on other sites
stevasaurus 23,817 #14 Posted Friday at 07:58 PM I hate to say it, but why would you want to make any Tecumseh a Pull Start ?? My right arm is 3" longer then my left because of Pull Start Tecumseh's. 1 Share this post Link to post Share on other sites
ebinmaine 80,488 #15 Posted Friday at 10:32 PM 2 hours ago, stevasaurus said: I hate to say it, but why would you want to make any Tecumseh a Pull Start ?? My right arm is 3" longer then my left because of Pull Start Tecumseh's. The PO has a Kohler. This picture shows Tecumseh engines. Share this post Link to post Share on other sites
pfrederi 21,103 #16 Posted Friday at 11:23 PM 3 hours ago, stevasaurus said: I hate to say it, but why would you want to make any Tecumseh a Pull Start ?? My right arm is 3" longer then my left because of Pull Start Tecumseh's. The HH70 we put on my L-107 in back in the early 90s will fire up after 1 0r 2 pulls maybe 3 in the winter../and she has been working all those years. 1 Share this post Link to post Share on other sites
Thegearhead0324 1,819 #17 Posted 13 hours ago If I’m not too late to the party, and you need the battery relocated for room, as what @adsm08 mentioned, here’s what I did with mine. I did it because I kind of didn’t like the battery where it could be seen. 1 Share this post Link to post Share on other sites
