Docwheelhorse
Anybody a Hydraulics Expert???
Docwheelhorse
Hello All---I put my new log splitter together about a month ago and filled it with nearly 9 gallons of John Deere Hygard Hytran oil (suppose to be the best hydraulic oil going---plus my friend owns the shop and I got a deal :hide: ). Anyways---I ran the stuffing out of the unit today (5 cords) and was very pleased with its performance---I noticed the tank getting warm and decided to stick the thermometer I borrowed :scratchead: from Sparky in the tank---well it read 135 and stood there even after 2+ hours of constant splitting. I think that temp is fine but I just wondered in an "ideal" situation is that too cold, too hot or just right from a performance/longevity standpoint?
Thanks!!!!!
Tony
Sparky
I dont have an answer for ya but you better return my thermometer or I'm callin the cops :scratchead: .
Mike..........
Duvall
We use mixers at work with large hydraulic pumps and motors.
The two large mixers have 125 hp motors on them. We do regular PM checks on them. Depending on the product in the mixer the temps in the hydraulic tank is between 120-140 degrees.
Docwheelhorse
Thanks Duvall---on another note, how often should I change the hydraulic oil (how many hours of use??) There is a filter and like I said---it holds 9 gallons.... :scratchead:
Appreciate the response
Tony
Indy w h
Ur oil temp sounds about right after splitting all that wood. Ur oil
geets hot because of goingthrough the pump under pressure. As
of how long on a oil change , about every four years unless you
get moisture in the tank or in the oil. That causes major pitting of
the pump piston causing it to not build pressure. There u have it
Indy
