tractor. 3 #1 Posted September 20 Hey yall. So I have a wheel horse b80 with a kohler k181s with a starter generator. (the engine was swapped at some point by the previous owner) the engine runs great, it starts up good, but its not charging, I have it all hooked up right, but its not charging enough to matter. I was just wondering do any of you know any problems I could be having, and how to go about fixing them. Thank you all. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,483 #2 Posted September 20 This older Kohler service manual has a section on the starter/generator Share this post Link to post Share on other sites
ri702bill 12,972 #3 Posted September 20 5 hours ago, gwest_ca said: This older Kohler service manual The newer (cost reduced) regulators no longer have the nice screw adjustments. Instead, you have to bend the spring mounting tab to lengthen or shorten the springs to adjust to suit. A tedious process as a little is usually too much! Share this post Link to post Share on other sites
squonk 48,056 #4 Posted September 20 Make sure the short wire underneath the regulator that goes to the gen is broken. 1 Share this post Link to post Share on other sites
sqrlgtr 3,857 #5 Posted September 20 1 hour ago, squonk said: Make sure the short wire underneath the regulator that goes to the gen is broken. pretty sure @squonk means not broken. 2 Share this post Link to post Share on other sites
adsm08 5,117 #6 Posted September 20 First things first, and this thread seems to be skipping around. Diagnose, don't load the parts cannon. 1) Check the wire @squonk mentioned. 2) Take a base-line voltage measurement at the battery, with the engine off and running. It should be near 13.5 engine running, it should not be less than the static voltage reading. 3) While running, measure voltage with the F terminal of the generator grounded. If the generator is working voltage should shoot up, and the engine should bog a bit. That indicates a regulator issue. 3A) If that DOES NOT happen, you have a generator issue. If the test indicates a regulator issue remove the cover from the regulator and inspect for broken/burnt wires and carbon build up on contacts. It can also be informative to start the engine, with the cover off, in the dark, and look for arcing where it shouldn't be. Since the regulator control voltage by dithering a set of contacts to control field coil ground carbon buildup on the contacts can negatively impact charging performance. The normal arcing that happens in this process can also wear the contacts, like a spark plug or set of points, making adjustments needed. Do NOT make adjustments with the engine running. 3 Share this post Link to post Share on other sites
FLtractor 219 #7 Posted 5 hours ago On 9/20/2026 at 6:16 AM, squonk said: Make sure the short wire underneath the regulator that goes to the gen is broken. Evening Squonk, my S/G for my K181 not turning over but was professional bench tested and it works but was told the voltage r regulator doesn’t charge. My question is the wire underneath my voltage regulator here.. does that anything to do with the starter turning over when key turned or that’s just the batter power- to ignition switch to the 2 terminal on the S/G to voltage regulator. Picture or my under wire appears tab not supposed be bent and wire may be frayed needed replacing Share this post Link to post Share on other sites
pfrederi 21,145 #8 Posted 5 hours ago That wire is what feeds the generator output to the regulator and then after the regulator regulates that out put it goes to the battery Share this post Link to post Share on other sites
FLtractor 219 #9 Posted 5 hours ago (edited) 20 minutes ago, pfrederi said: That wire is what feeds the generator output to the regulator and then after the regulator regulates that out put it goes to the battery So The battery powers the generator.. electrical current flows through that wire underneath to power the voltage regulator and then electrical current flows through the middle outside front terminal to the + battery terminal to keep it charged? So it’s a related self contained loop cycle if you will.. not sure if official electrical term. If the powers flows into the voltage regulator underneath then what is wire going to terminal 1 here from voltage regular to S/G for? Edited 5 hours ago by FLtractor Share this post Link to post Share on other sites
squonk 48,056 #10 Posted 4 hours ago YOU STILL NEED TO CLEAN THOSE TERMINALS! Share this post Link to post Share on other sites
FLtractor 219 #11 Posted 4 hours ago (edited) 35 minutes ago, squonk said: YOU STILL NEED TO CLEAN THOSE TERMINALS! Yes I know and I will… I was wanting to understand more about the S/G and voltage regular areas in my post to you on here. Edited 4 hours ago by FLtractor Share this post Link to post Share on other sites
953 nut 69,104 #12 Posted 4 hours ago 1 hour ago, FLtractor said: My question is the wire underneath my voltage regulator here.. does that anything to do with the starter turning over when key turned No, the heavy wire from the battery "+" to the switch, the heavy wire from the switch to the S/G "A" terminal and the ground wire back to the battery "-" terminal are the only components in the start wiring. I run the ground wire directly from the battery to one of the S?G mounting bolts. The diagram below should be helpful. Share this post Link to post Share on other sites
FLtractor 219 #13 Posted 3 hours ago 4 minutes ago, 953 nut said: No, the heavy wire from the battery "+" to the switch, the heavy wire from the switch to the S/G "A" terminal and the ground wire back to the battery "-" terminal are the only components in the start wiring. I run the ground wire directly from the battery to one of the S?G mounting bolts. The diagram below should be helpful. So your diagram in conjunction with my 856 specific. Helps thank you. on 856 diagram- what does the F terminal with wire to voltage gen front terminal on far right do? If power goes INto voltage regulator through terminal A. Does power go back into S/G through terminal wire F? Share this post Link to post Share on other sites
953 nut 69,104 #14 Posted 3 hours ago This B&S Manual gives a good explanation of how the S?G works. Share this post Link to post Share on other sites
