Bill D 3,115 #1 Posted 15 hours ago (edited) Trying to find new bearings for these pulleys. The V pulley had a 6203-12 bearing in it, but it was loose and had been shimmed in a failed attempt to make it work. What bearings do I need? Thanks Edited 15 hours ago by Bill D Share this post Link to post Share on other sites
peter lena 10,020 #2 Posted 13 hours ago @BillD got cha ! did some snoopin around , ,lucky you ! https://www.google.com/search?q=101763+bearing&rlz=1C1CHBF_ most important feature ? WIDE EASLY REMOVABLE SIDE GREASE SHIELDS ! flat pocket screwdriver / small flat putty knife , pops those right out , wipe out original lube ? carb cleaner flush , then LUCAS EXTRA HD , GREEN CHASSIS GREASE , 550 deg flash point , polyurea rated , anti sling , completely transforms that bearing into a smooth / quiet / long lasting unit for brutal set ups . every bearing in my pto, mule drive , mower decks , related , needle bearings , have this , did this change over years ago , never had a failure , what an opportunity ! pete Share this post Link to post Share on other sites
squonk 47,920 #3 Posted 13 hours ago 1 hour ago, Bill D said: Trying to find new bearings for these pulleys. The V pulley had a 6203-12 bearing in it, but it was loose and had been shimmed in a failed attempt to make it work. What bearings do I need? Thanks I believe the 2 pulleys use 2 different bearings. One of which is the 6203-12. I can find out the number for sure when I can get out to the shop Share this post Link to post Share on other sites
squonk 47,920 #4 Posted 13 hours ago (edited) @Bill D One bearing is a 1630-2RS .75 X 1.625 x .5" Other bearing is 6203-12 is .75 x 1.57 x .47" Edited 13 hours ago by squonk 1 2 Share this post Link to post Share on other sites
JoeM 10,173 #5 Posted 12 hours ago (edited) Both of my sheeves used the same bearing, if your sheeve bearing fit was shimmed best to get replacements. Got the 6203-12 bearings on ebay Edited 12 hours ago by JoeM Share this post Link to post Share on other sites
cleat 9,254 #6 Posted 12 hours ago 49 minutes ago, squonk said: @Bill D One bearing is a 1630-2RS .75 X 1.625 x .5" Other bearing is 6203-12 is .75 x 1.57 x .47" I have a couple of mules here with the cast pullies and they are the same as Squonk's with a 1630 and a 6203-12. 2 Share this post Link to post Share on other sites
squonk 47,920 #7 Posted 12 hours ago I have 2 mules here as well. The 1630 fits into the V pulley and the 6203 fits into the flat pulley. Share this post Link to post Share on other sites
Bill D 3,115 #8 Posted 11 hours ago Thanks. I wonder why the different bearings. Share this post Link to post Share on other sites
sqrlgtr 3,745 #9 Posted 8 hours ago 3 hours ago, cleat said: I have a couple of mules here with the cast pullies and they are the same as Squonk's with a 1630 and a 6203-12. 3 hours ago, squonk said: I have 2 mules here as well. The 1630 fits into the V pulley and the 6203 fits into the flat pulley. Same here. Share this post Link to post Share on other sites
JoeM 10,173 #10 Posted 26 minutes ago 14 hours ago, squonk said: I have 2 mules here as well. The 1630 fits into the V pulley and the 6203 fits into the flat pulley. looks like someone stuck the wrong bearing in my v pulley. going to have to take a closer look. Share this post Link to post Share on other sites
