FLtractor
What model Wheelhorse?
FLtractor
Marketplace listed.. what model? Seller asking $200.00. Hasent Ran in years, needs carb rebuild, always been in same family ad states.
Edited by FLtractor
  • Excellent 3
Retired Wrencher
Fl tractor. This will make a good project for you. Take your time with it. Enjoy it when it is done.
Pullstart
3 speed, hydraulic lift, lots of ground clearance, super heavy duty frame and front axle.  What’s not to love?
  • Like 4
  • Excellent 2
WHX??
Rough around the edges ... go get it. :auto-layrubber:
953 nut
Seems like I have seen one or two of them someplace,
go get it-put it on the rotisserie and have some fun with it.
  • Excellent 4
FLtractor
9 hours ago, Ed Kennell said:
953 or 1054       Go get it.
What years made? How compare to my 856 ? In terms of engine HP and overall durability ect
Ed Kennell
953
9=9hp
5=gear drive transmission
3=1963
1054
10=10hp
5=gear drive
4=1964
856
8-8hp
5=gear drive
6=1966
The 953 and 1054 have 15" rear wheels and a hydraulic lift.
The 856 has 12" rear wheels and a manual lift.
Edited by Ed Kennell
Handy Don
Hydraulic lift comes from a separate pump called an HY-1 or HY-2. This is different from the later Sunstrand- or Eaton-powered lifts where the pump was integral to the transaxle.
oliver2-44
Is it on the trailer yet?
What are you waiting for
  • Haha 1
FLtractor
3 hours ago, Ed Kennell said:
953
9=9hp
3=1963
1054
10=10hp
5=gear drive
4=1964
856
8-8hp
5=gear drive
6=1966
Thank you for info.
FLtractor
How difficult to service and fill the hydraulic pump and lines?
FLtractor
Debating if I need another.
  • Confused 1
Handy Don
Good question for @953 nut or @ri702bill :)
ri702bill
The Hy-xx series stand alone pumps are fairly simple - pump, directional valve, & reservoir all in one. If the pump, cylinder & lines are completely empty, it will require filling the reservoir a few times as the fluid makes it way thru the lines & cylinder when activated.
You NEED to determine just what fluid in in there - It could be oil, ATF, or a mineral based recirculating "oil".Try and use the same... others my sprcify one over the other. The HY-2 and HY-3 manual is of little help - it just provides a now obsolete WH part number for the fluid...
davem1111
  • Haha 2
pfrederi
They are rugged tractors...but as I get older the fact that it weighs 192 lbs more than an 856 is becoming more and more an issue when it comes to working on them...:(
c-series don
You came to the wrong place if you’re asking for advice on that! These guys are a bunch of enablers 🤣🤣🤣
8ntruck
:text-yeahthat: @c-series don included.
  • Haha 2
1054 Project
953/1054's are a fun project. Before/After attached.
  • Excellent 3
Retired Wrencher
Richard: Nice looking bunch of 9,s and 1053,s.That will get the job done.
Retired Wrencher
Paul there is always way to get around that. :text-yeahthat: A electric lift mounted to the ceiling of the garage and a bunch of moving dollies when parts are missing like the rear end front axle that’s how I get around it. And I also have four wheeler lift. I put 6 x6`s  on the lift for more height. I never throw scraps of wood away like 4 x 4‘s or six by sixes and some two by fours. Definitely good for adding height.As a matter of fact on Saturday, I started taking apart the 1056 because somebody broke the set pin lack of a better word I guess for the shifter I couldn’t put it into gear so I had to take out the a transmission and put a new locking pin and set nut. Luckily, I had a few of them hanging around that I bought on eBay. Should be all back together.
Edited by Retired Wrencher
gwest_ca
From the lubrication charts for the 953, 1054 and 1054A item H-1 for the hydraulic lift
Ed Kennell
That must be the way they were built around that one piece body weldment.   A lotta :angry-cussing::angry-banghead:  to remove the fuel tank.
953 nut
17 hours ago, FLtractor said:
How difficult to service and fill the hydraulic pump and lines?          The pump is down between your feet and has a threaded plug that is removed to add oil
Debating if I need another.                          :scratchead:            Wrong question, none of us NEED another     :hide:      we just want another.
