DZG 46 #1 Posted 14 hours ago I was at an auction yesterday and bought this... It fired right up, blower works, and it moves fine. I did some reading and i just want your opinion on how decent of a mower it is? Its a 314A. I bought it to blow snow as itll be eaiser to do my sidewalks and stuff with then my quad. I gave 230bucks for it. 5 8 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,449 #2 Posted 14 hours ago It should be a 1985 model 21-14KE01 Everything we have on the model in no particular order. https://www.wheelhorseforum.com/search/?q=21-14ke01&quick=1&type=downloads_file Share this post Link to post Share on other sites
Ed Kennell 46,954 #3 Posted 12 hours ago Great deal. the working tall chute blowers sell for $200. Just a word of caution, the 314A has the weaker Eaton 700 hydro transmission that is not approved for ground engaging implements like a dirt plow or disc or grader blade. It should work fine with the blower or a mowing deck. Another quirk with the 700 hydros is the engine is not running, they can not be rolled. Do not attempt to tow as the transmission may be damaged. 7 1 Share this post Link to post Share on other sites
Handy Don 17,296 #4 Posted 12 hours ago (edited) 1 hour ago, DZG said: your opinion 14 is plenty of oomph. @Ed Kennell covered the transaxle Keep the revs up and a steady feed of snow when blowing and it’ll do great. Here's the Checklist Thread to help you welcome the new horse to the herd! You got a good deal Edited 12 hours ago by Handy Don 3 Share this post Link to post Share on other sites
Bar Nuthin 3,008 #5 Posted 12 hours ago 1 hour ago, DZG said: I gave 230bucks for it. Nice! You bought a snowblower and got a free tractor! 5 Share this post Link to post Share on other sites
ri702bill 12,781 #7 Posted 11 hours ago (edited) Excellent score - do the fluids & filter change, grease the tractor & blower fittings. You MAY wish to add another 9 or 10 cross links to fill the spaces between the existing ones on each rear tire Your kidneys will thank you. If the tires already have tubes, you may also want to fill them with either RimGard or winter windshield fliud. Takes about 5 gallons per tire - adds about 35 lbs of weight per tire. Heavy snow will most likely may be an issue without wleel weights... Edited 10 hours ago by ri702bill 2 Share this post Link to post Share on other sites
rmaynard 17,520 #8 Posted 10 hours ago (edited) When doing transmission filter changes, I always use Wix filters: Sorry no filter on this one Edited 8 hours ago by rmaynard Share this post Link to post Share on other sites
oliver2-44 11,692 #9 Posted 10 hours ago Not trying to scare you off, but horses are herd animals. I hope you have lots of shed room. Now that you have one, MANY more will follow. 5 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,449 #10 Posted 10 hours ago This tractor uses an Eaton 700 hydro so there is no transmission oil filter. 2 Share this post Link to post Share on other sites
DZG 46 #11 Posted 4 hours ago Awesome so i did pretty well lol. I literally just bought it to snowblow. My quad with bucket is a real pain at times. lol. I plan on changing all the fluids before i really start running it. I did read the 700 is a bit on the weak side....but like i said i dont plan on using it hard. I got a cub and 2N for that stuff lol 1 Share this post Link to post Share on other sites
Brockport Bill 2,451 #12 Posted 2 hours ago other than the obvious maintainence tasks one that is often overlooked is to replace the gas line - -they can rot internally and the little fragments travel potentially to carb -- also suggest washing out gas tank - enjoy ! 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,587 #13 Posted 2 hours ago Nice score. I like the tall chute single blower for clearing snow to. Best of luck. Share this post Link to post Share on other sites
