DZG
Just bought a wheelhorse
Ed Kennell
Great deal. the working tall chute blowers sell for $200.     Just a word of caution, the 314 has the weaker Eaton 700 hydro transmission that is not approved for ground engaging implements like a dirt plow or disc or grader blade.     It should work fine with the blower or a mowing deck.    Another quirk with the 700 hydros is the engine is not running, they can not be rolled.    Do not attempt to tow as the transmission may be damaged.
  • Like 7
Handy Don
1 hour ago, DZG said:
your opinion
14 is plenty of oomph.
@Ed Kennell covered the transaxle
Keep the revs up and a steady feed of snow when blowing and it’ll do great.
Here's the Checklist Thread to help you welcome the new horse to the herd!
You got a good deal
Edited by Handy Don
Bar Nuthin
I gave 230bucks for it.
Nice! You bought a snowblower and got a free tractor!
  • Like 5
SylvanLakeWH
:eusa-clap:
ri702bill
Excellent score - do the fluids & filter change, grease the tractor & blower fittings.
You MAY wish to add another 9 or 10 cross links to fill the spaces between the existing ones on each rear tire Your kidneys will thank you.
If the tires already have tubes, you may also want to fill them with either RimGard or winter windshield fliud. Takes about 5 gallons per tire - adds about 35 lbs of weight per tire. Heavy snow will most likely may be an issue without wleel weights...
Edited by ri702bill
  • Excellent 2
rmaynard
When doing transmission filter changes, I always use Wix filters:
Sorry no filter on this one
Edited by rmaynard
oliver2-44
:text-welcomeconfetti:
Not trying to scare you off, but horses are herd animals.
I hope you have lots of shed room.
Now that you have one, MANY more will follow. :icecream:
  • Like 5
gwest_ca
This tractor uses an Eaton 700 hydro so there is no transmission oil filter.
DZG
Awesome so i did pretty well lol.
I literally just bought it to snowblow. My quad with bucket is a real pain at times. lol.
I plan on changing all the fluids before i really start running it. I did read the 700 is a bit on the weak side....but like i said i dont plan on using it hard.
I got a cub and 2N for that stuff lol
Brockport Bill
other than the obvious maintainence tasks one that is often overlooked is to replace the gas line -  -they can rot internally and the little fragments travel potentially to carb -- also suggest washing out gas tank - enjoy !
JERSEYHAWG /  Glenn
Nice score. I like the tall chute single blower for clearing snow to.
Best of luck.
