Retired Wrencher
Alternate power Source
Retired Wrencher
I was talking with my cousin today and he mentioned ignition module coil,  He was a mechanic in the Air Force. Rebuilding engines stuff like that so it sounds like he knows what he’s talking about.
This is for Kohler engines. I found on eBay for $35. It covers K141 all the way up to 301s and beyond just wondering if anybody has ever tried This. Would be nice not to mess with points anymore more.  Let me know your experience with these. Any comments are welcome.
ebinmaine
Do you have any pics or links?
I've seen a module that replaces the  condenser but the points are still needed.
Supposedly the points do wear less.... but Kohler points really don't get replaced often anyway.
ebinmaine
Retired Wrencher
Let me get back to you.
Edited by Retired Wrencher
Retired Wrencher
Eric I was eBay it comes right up but limited info.
ebinmaine
I'd be interested to see more info. If it's worth doing, I'd try it.
Retired Wrencher
Still waiting. Seems to be slow on the transfer. From Picks.
Retired Wrencher
Ok Eric here is the pick.
ebinmaine
44 minutes ago, Retired Wrencher said:
here
I believe that's for a Pullstart engine.
To the best of my knowledge....
That will NOT work for any Starter/Generator or gear drive starter engines.
@squonk
953 nut
That is a standard magneto used for ignition only. Can be used on any Kohler K series if you already have the correct flywheel and mount.
953 nut
@squonk
Looks like this may have been used when the electronic breakerless ignition systems were being introduced.    :scratchead:   New one on me too.
Magneto ignition coil used with points and condenser 4775520-S
Used in the K301S-47147b with Bendix starter and 10 amp stator. Conflicting info in the Kohler parts manuals.
1968 Charger 12 model 1-7231 - Late production but tractor model number stayed the same
1968 Raider 12 model 1-6231 - Late production but tractor model number stayed the same
1968 Electro 12 model 1-7235
pfrederi
That has nothing to do with breakerless
