BuffaloD200
Ark Loader Spool Valve
BuffaloD200
Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
I noticed the power beyond port is connected to the reservoir return.  Is that right?
Anyone see anything blatantly incorrect?
BuffaloD200
Some extra photos.
Also, 1980 WH D-200 with 550? Loader
wallfish
Looks correct to me. The Power beyond port is an out port.
What kind of trouble are you having that needs to get sorted out?
Handy Don
I don’t know that control valve specifically, but with Power Beyond (typically labelled “N”) connected to the reservoir is there a separate Tank (“T”) port on the valve and, if yes, where is it connected?
T and N are both “out” ports, but they have different purposes.
always gets plumbed directly to the reservoir (i.e. the Tank), can often use lower-pressure hoses, and should never see much pressure. It’s job is to route fluid from the non-pressure side of a cylinder into the reservoir while the pressure side of the cylinder is being filled
N typically get plumbed to the P port on an additional control valve (which must have its T plumbed to the reservoir) via hose that can support FULL PRESSURE. N's job is to allow working pressure fluid to reach “beyond” the current valve while still supporting full pressure/flow to cylinders attached to the current valve.
  • Heart 2
BuffaloD200
The control handles move, but nothing else does.  No noise, no cylinder movement.
My guess is the spool valve internal seals are shot and fluid just moves past them.
The tractor sat for an unknown amount of time, and the previous owner said he was pretty sure the spool valve needed to be rebuilt.
Hoses are relatively new, I took the cover off the pump and the seal is in good condition.  PTO friction material is in good shape as well.
wallfish
Have you verified the pump is actually pumping? You can remove that return hose going to the reservoir and direct it back into the reservoir or catch it in a container.
See if there's anything in the manual. You should be able to find it here
https://www.wheelhorseforum.com/search/?q=Ark loader&quick=1&type=downloads_file
Handy Don
:text-yeahthat:
Even with shot seals, if there is useful fluid flow from the pump to and through the control valve, then moving the controls would get you some movement or noise.
Even a stuck open pressure release valve would not divert ALL of the flow unless there was a blockage somewhere downstream.
BuffaloD200
I haven't tried that.  I'll disconnect one end and use a catch bucket tonight.
21 hours ago, Handy Don said:
:text-yeahthat:
I didn't see a label on that.  I assumed it was a mounting bolt or something.
I'll see if I can turn that plug loose and take a look.
Handy Don
 Its just that the location between the A and B ports for the two cylinders seems appropriate.
That said, I’m assuming that the unit did work at some point with the current plumbing so I would leave that alone until other diagnostics are done first.
Anyway, unless you are planning add more hydraulically-controlled stuff, the N (power beyond) to reservoir is suitable plumbing. Actually, this is incorrect. SEE NEXT POST.
Edited by Handy Don
Handy Don
Surprised no one called me out on this, but the T port must be connected to the reservoir or else there is no exit for fluid from the low pressure side of the cylinders when they are being activated.
8ntruck
I'm thinking that if the N port is connected to the tank would be equivalent to a short in electrical wiring - the pressure and flow would drain off into the tank, not leaving any to operate the device connected to the directional valve.  Hydraulic pressure and flow is like students - it follows the path of least resistance.
Handy Don
The N flow gets intercepted when a control in the valve directs fluid to its A or B port.
A chain of valves with N’s connected to P’s where the last valve’s T connects to the reservoir is a complete circuit. Any valve in the chain can divert the flow to a cylinder thus temporarily “starving” the valves downstream. Holding that valve open at the cylinder’s travel limit, causes the pressure relief valve to dump the flow direct to the reservoir.
On equipment where multiple cylinders must operate simultaneously, they are all controlled via a single, “ganged” control where a single supply “gallery” ports to all the cylinder valves. The ARK loader’s two-spool control is a “ganged” control.
Edited by Handy Don
wallfish
Mine were all marked IN OUT BYD and the rest were the cylinder ports.
Handy Don
So “IN” was “P”, “OUT” was “T”, and BYD was, “N”.  Unless used, BYD should be plugged.
Edited by Handy Don
wallfish
@ebinmaine Hey Eric, can you post a pic of that loader valve?
Handy Don
The ARK control may be one which has OUT and BYD internally joined unless a special plug is inserted to separate those two ports.
Need the specs.
ebinmaine
Be happy to. Later today.
BuffaloD200
We had a bit of rough weather the last couple nights, haven't had the opportunity to play with it.
ebinmaine
wallfish
Is there a port on this corner? If so, move the plug from it to the BYD and the hose to that port.
None of your pics show it very well but I can see some lettering there like the ID for a port.
IMG_20260830_164058970.jpg.e4abe91cf6e8d2ee6b6eaea0f53c23a5.jpg.cd651ad6eae9c84bf6782a97c305a5b8.jpg
BuffaloD200
Yes there is an out port on the front.  That is probably at least part of my problem.
wallfish
Or the cause of it but I doubt that.
What's going on now? Pump not pumping?
Handy Don
Without a doubt, confirming pump flow is the correct start point.
BuffaloD200
Sorry, I've been trying to get this engine to start.  Haven't been able to test the hydro pump lately.
Engine fires and then quits after a few seconds.  I'm going to just replace all the fuel line - I have a suspicion there's some crud in the line.
  • Similar Content
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
