Dave D.
Just joining finally time to work on the $40 Suburban 551
Dave D.
Years ago, I saved an old Wheel Horse from a scrap pile for $40. Finally looking at getting it together now.
I'm finishing up on my old Ariens Garden Tractor steering and then I'll get on the old Wheel Horse.
It's in the shipping container and when it gets a little cooler, I'll pull it out for some better pictures. Looking forward to getting some information on this. Others have suggested it is a 1961 Suburban 551 from the pictures.
Thanks,
Dave
No engine.
Dave D.
Thinking I'll just get it running with a Predator 212cc engine and enjoy it.
Planning to do a trans flush and see what it looks like in there.
Someone has cut off the rod for the clutch pedal. It's there just cut. Got to figure how to align it and weld it back.
Hunting up all the pieces in the shipping container.
Looking forward to getting some great information on this cool little tractor.
Dave
WHX??
:WRS:
Manuals should be in the files section. It should have had a electric start Tecumseh HH50 in it but a k91 is acceptable. Or a Briggs or predator.
SylvanLakeWH
:text-welcomeconfetti:
ebinmaine
Dave D.
Thank you. Looking forward to getting  this little tractor going. Been searching trhough the threads on flushing the transmission.
Haven't seen many Wheel Horse tractors around here in NC. I love the history of the old equipment.
The gear stick is missing the hardware to lock it in the tranny. Gotta make sure it's not down in there, The gears don't look too bad through the hole, but it's been sitting in the storage for 20 + years. I think it has the 5007 3-piece tranny? Digging into the transmission seems a little scary. Leaning towards a rolling restoration and not modifying anything, then maybe a restoration later.
I'll get it out and take more pictures.
Thanks for the welcome and encouragement. Been too hot to do much on it lately, but Fall is coming.
Thanks,
Dave
squonk
551 has a 2 piece most likely  a # 5007
Edited by squonk
parsonsponyz
:text-welcomeconfetti:  You're starting with a nice tractor.
rjg854
:text-welcomeconfetti::rs:
Dave D.
Thank you, I'll take some more pictures soon. Got to get all the parts together and start accessing it.
Looking forward to some great information and advice on these little tractors.
Thanks,
Dave
c-series don
@Dave D. With all the help and information here on Red Square I would not hesitate to take the transmission apart to fix it. A guy by the name of Jake Kuhn used to sell a bearing and gasket kit for it, I’m not sure if he still does? He’s out west, Michigan or Wisconsin I believe. @stevasaurus is our resident expert on those transmissions. He’s usually around here to help and answer any questions you may have. You can do it!!
Dan 312-8
Welcome to Red Square, where there's wealth of information available in both manuals and tribal knowledge. Gotta love a $40 Suburban with a $750 weight on the front!
You got great bones there to start.
:text-welcomewave::wh:
wallfish
:WRS:
The original engine would've been a Kohler K91 but there were some made using a Clinton B1290. I would skip the Preditor engine and find a K91. Old stuff looks funny with a newer style engine on it. I'd also clean it up first and see if the patina is salvageable before just spray bombing it. :twocents-02cents:
Post some pics of the trans which will determine if it's a 551 or a 401.
That original front weight is a rare item and worth more than the tractor itself is.
Post wanted ads on here for the parts you're missing like engine, gas tank, belt guard heat shield, shifter etc.  And look often on epay and FB market place
