953 nut 69,844 #2 Posted August 29 Thought for sure this was going to be a demonstration of how well the ROP bars held up. 2 Share this post Link to post Share on other sites
ri702bill 13,214 #3 Posted August 29 It's all fun & games until you exceed the side tilt limit... That video has it all - loss of steering control, loss of traction, and torture testing the pressurized lubrication system. Probably better to hit that area with weed killer... 2 Share this post Link to post Share on other sites
peter lena 10,091 #4 Posted August 29 @ri702bill @T-MoAGREE ON THAT ! done a lot of brush clearing with tractors , could personally feel the danger zone in that angle , basically it was his speed that made it scary . would also have weed killed it , minimizing bulk , pete Share this post Link to post Share on other sites
JoeM 10,317 #5 Posted August 29 Certainly pucker stuff! That ground is pretty common here in Greene Co. Pa. The farm boys here can make you nervous in these hey fields. I have frontage that is about the same and I have just about 40' of it that I can't mow. I slide to the ditch. There is a lot to learned for the vid. The best tip is keeping your front end higher then the rear wheels, very important. Notice when he is coming back around the tree and the front dips down how the machine starts to slide. The duals are a big help and he is working those turning brakes like a real pro. Lifts that brush hog just at the right time too! Wondering if he has filled tires? Good vid I probably would fill better in a smaller machine tho! But those days are over I would pass, lol. 2 1 Share this post Link to post Share on other sites
c-series don 12,533 #6 Posted August 29 Personally I wouldn’t let anyone near me when I was brush hogging after an experience years ago. I was cutting some light brush and had a guy with a weed wacker with a blade on it doing around the trees. All of a sudden it started shaking really bad, my first thought was that I sucked up a cable or wire rope. So I shut it down and lifted it up to inspect. As I was walking around I noticed a 8” gash that looked like a mouth opened up in the side of the unit. When I looked under it I noticed that one of the blades was missing! That explained the opening in the side of the deck. I quickly realized that could have severely injured or even killed the guy with the weed wacker. I looked everywhere for the blade, but couldn’t find it anywhere. I figured it probably buried itself somewhere in the underbrush. At that point I was done until I got new blades. Here’s where it gets crazy. A few months later I ran into the guy who owns the neighboring property. He said hey was that you that cut the underbrush on my neighbors property a while ago? I said yes, why do you ask? He said he found a brush hog blade stuck IN THE ROOF of his house!! His house was maybe a hundred feet away from where I was working but the blade was in the second story roof. It didn’t damage it, somehow it got stuck between the layers of shingles. When he noticed it he went up there and just pulled it out. He told me the blade was broken right at the mounting hole. I got really lucky that nobody got hurt or killed. Ever since then I would not allow anyone anywhere near me when I was cutting brush. I can’t imagine the energy that piece of steel had to punch through the deck and still travel that far and high?! 8 Share this post Link to post Share on other sites
lynnmor 9,051 #7 Posted August 29 Calling Charles Darwin, you missed one! 3 Share this post Link to post Share on other sites
ri702bill 13,214 #8 Posted August 29 1 hour ago, JoeM said: I slide to the ditch. And the morning dew will get you every time! 1 Share this post Link to post Share on other sites
ol550 879 #9 Posted August 29 Remember back years ago when the state would mow with 800 series Ford tractors with side mounted sickle bar mowers. If the road bank got to steep they would mow side by side to keep the upper tractor from sliding down and possibly turning over. 1 Share this post Link to post Share on other sites
8ntruck 9,355 #10 Posted August 29 I notice the side hills along the freeway that get mowed - on angles that I wouldn't even consider trying. 2 Share this post Link to post Share on other sites
ri702bill 13,214 #11 Posted August 29 1 hour ago, 8ntruck said: I notice the side hills along the freeway that get mowed - on angles that I wouldn't even consider trying. A perfect application for drone mowers?? Share this post Link to post Share on other sites
cafoose 3,882 #12 Posted August 29 My township uses one of these 8 1 Share this post Link to post Share on other sites
Beap52 2,516 #13 Posted August 29 By the end of the video, my nose was running and my eyes burning and itchy from the pollen he was stirring up. Grandpa would come in after brush hogging all day and his hood of the tractor would be yellow in pollen. If I did that, my eyes would have been swollen shut. Share this post Link to post Share on other sites
EB-80/8inPA 2,124 #14 Posted August 30 A friend of mine used to mow a slope as a favor to his neighbor. He could have used that dually set up. The day he rolled that tractor over was his last. 3 Share this post Link to post Share on other sites
c-series don 12,533 #15 Posted August 30 4 hours ago, Beap52 said: By the end of the video, my nose was running and my eyes burning and itchy from the pollen he was stirring up. Grandpa would come in after brush hogging all day and his hood of the tractor would be yellow in pollen. If I did that, my eyes would have been swollen shut. Boy don’t I know all too well about that! Last week someone here had pictures of them cutting a field with golden rod in it and I thought the same thing. Just looking at it made my eyes burn and my nose run. I certainly don’t miss those days!! 1 Share this post Link to post Share on other sites
953 nut 69,844 #16 Posted August 31 Here is the answer. Toro made one like this in the mid 1980s. 1 Share this post Link to post Share on other sites
