ebinmaine 80,708 #1 Posted August 26 For my old Ford truck I want to put a CB radio in there as part of the Retro theme. I have a vintage Uniden unit on the way. I want to use an antenna that would be very visible on the outside. Preferably some sort of metal. Not a fiberglass one. Preferably clamped to the passenger side mirror bracket. That's flat steel that is probably something like quarter inch thick by 1.5 wide. How do I go about figuring out what sort of antenna I want that is as tall as possible and the correct length for good tuning? Share this post Link to post Share on other sites
SylvanLakeWH 32,515 #2 Posted August 26 Been a minute, but I had best luck with a magnet mount whip antenna... no clue what brand... Duals mounted on my old F-150 mirrors didn't seem to work... going back to 1981ish... so Share this post Link to post Share on other sites
lynnmor 9,040 #3 Posted August 26 If there is a major truck stop over there on I95, you might want to check it out. I have seen things at truck stops that might not be found elsewhere. 2 Share this post Link to post Share on other sites
8ntruck 9,301 #4 Posted August 26 CB antenna terms that come floating up out of my memory include 1/4 wave, 1/2 wave, and full wave antennas. I'm thinking you will probably want a 1/4 or 1/2 wave type. I don't remember what the length was, though. Share this post Link to post Share on other sites
Ed Kennell 47,343 #5 Posted August 26 My radio guy installed this one on my 2010 F-150. The black thingy is slid up and down to tune and locked with set screws. 1 Share this post Link to post Share on other sites
squonk 48,125 #6 Posted August 26 Back in my Chevy garage days our shop foreman had this long honkin CB antenna on the roof of his pick up. He thought he was better than us so he ate his lunch at 1:00. He would sit in his truck and talk on the CB. We always played jokes on each other so one day me and another guy came back from lunch and I had a banana peel to toss out. I climbed into the back of the truck pulled his antenna down and stuck the peel on the end and gently let it straighten out. Then waited for him to see that peel on his antenna. 4 Share this post Link to post Share on other sites
Wayne0 1,634 #7 Posted August 26 I had a 6' Fire Stick on my old Wagoneer, It worked awesome, but you don't want glass. I recommend a K-40 if they still make them 1 Share this post Link to post Share on other sites
ri702bill 13,067 #8 Posted August 26 That's going back 45 years for me! Twin 18" Fire Sticks on my 1970 Wagoneer's low-mount mirrors. And a Cobra 23XL Radio. Share this post Link to post Share on other sites
8ntruck 9,301 #9 Posted August 26 I just remembered another thing. An electrical engineer friend helped me set up my antenna, using a standing wave meter. 1 Share this post Link to post Share on other sites
Handy Don 17,474 #10 Posted August 27 42 minutes ago, 8ntruck said: I just remembered another thing. An electrical engineer friend helped me set up my antenna, using a standing wave meter. Getting a ¼ or ½ wave antenna perfectly tuned makes a huge difference in signal clarity. 1 Share this post Link to post Share on other sites
ebinmaine 80,708 #11 Posted August 27 (edited) 10 hours ago, Handy Don said: Getting a ¼ or ½ wave antenna perfectly tuned makes a huge difference in signal clarity. I vaguely remembered that from a couple friends having ham radios about 30 years ago. I think with a CB frequency, you have to have quite a long antenna to approach those numbers. For the visual aspect of it, I'd like to have as much height over the roof as possible .. up to about 12 or 13 ft total. Edited August 27 by ebinmaine Share this post Link to post Share on other sites
Handy Don 17,474 #12 Posted August 27 (edited) 2 hours ago, ebinmaine said: CB frequency, you have to have quite a long antenna Yep. A straight wire antenna would be 36 feet long! Shorter physical lengths use wire coils and other cool electronic tricks. Edited August 27 by Handy Don 1 Share this post Link to post Share on other sites
ebinmaine 80,708 #13 Posted August 27 3 hours ago, Handy Don said: Yep. A straight wire antenna would be 36 feet long! That might be pushing height extremes a little bit 3 hours ago, Handy Don said: Shorter physical lengths use wire coils and other cool electronic tricks. That would explain why I see a lot of fiberglass antennas that say they have a copper coil wrapped around them 1 Share this post Link to post Share on other sites
c-series don 12,447 #14 Posted August 28 I think no matter what, you need two antennas just for the cool factor. Even if only one is hooked up, two will look cooler! 2 1 Share this post Link to post Share on other sites
ebinmaine 80,708 #15 Posted August 28 6 hours ago, c-series don said: two will look cooler! Definitely agreed. If I can find a decent looking metal single antenna that works ok - on the mirror bracket - for a low price - two could happen. From what I'm reading that could be a tough catch. Good signal needs to happen above the vehicle roof line. I wouldn't even be using the radio that often but the particular person I am would want something capable. 2 Share this post Link to post Share on other sites
Thegearhead0324 1,843 #16 Posted August 29 (edited) On my 95 Chevy, I have a cb mounted on the top headliner where the windshield and roof meet. As for the antenna, I have the mount on the side of my toolbox, and when not in use I keep the 4’ antenna off, but if I ever wanted to I just screw it on the mount. Cobra 29ltd cb and firestick antenna. Edited August 29 by Thegearhead0324 1 Share this post Link to post Share on other sites
ebinmaine 80,708 #17 Posted August 29 I've ordered a Uniden magnet base and this Browning BR-92-BL Antenna. Excellent reviews. Tunable. This will give a good tall stand out appearance too. Blue anodized coil will look good on my blue truck. I stuck with a magnet mount for two reasons. 1. Reception from the roof top center seems universally recognized as good. 2. Going in & out of the barn with the 9 foot doorway it'll either snap through or I'll lay it over manually. 1 2 Share this post Link to post Share on other sites
