FLtractor 223 #1 Posted August 23 Saw this on marketplace.. thoughts on it.. practicality, useful for work? Price? Both engines make it have double the horsepower.. to lift it off the ground and shoot flames? 5 2 Share this post Link to post Share on other sites
adsm08 5,146 #2 Posted August 23 Florida Man strikes again. Florida Man is my favorite superhero. 3 2 Share this post Link to post Share on other sites
EB-80/8inPA 2,116 #3 Posted August 23 You won’t find another one like it. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #4 Posted August 23 18 minutes ago, FLtractor said: practicality Sure?? 18 minutes ago, FLtractor said: , useful for work? DEFINITELY. You bet all you own I'd put a trailer hitch on that pull logs. 18 minutes ago, FLtractor said: Price? Given the amount of engineering and fabrication there... that seems fair considering the condition. 18 minutes ago, FLtractor said: Both engines make it have double the horsepower There's where the usability is limited. In all seriousness, the extra weight holding the front down would be cool but the extra power doesn't matter. Share this post Link to post Share on other sites
Sparky-(Admin) 26,359 #5 Posted August 23 A useless tractor. Personally I would avoid it, but that’s just me. 5 Share this post Link to post Share on other sites
squonk 48,121 #6 Posted August 23 20 minutes ago, Sparky said: A useless tractor. Personally I would avoid it, but that’s just me. Not entirely useless. You'd get lots of looks at a tractor show. @Pullstart could use it to tow his new motorhome from the middle of the field! 1 6 Share this post Link to post Share on other sites
FLtractor 223 #7 Posted August 24 3 hours ago, ebinmaine said: Sure?? DEFINITELY. You bet all you own I'd put a trailer hitch on that pull logs. Given the amount of engineering and fabrication there... that seems fair considering the condition. There's where the usability is limited. In all seriousness, the extra weight holding the front down would be cool but the extra power doesn't matter. Thanks for the breakdown Eric 1 Share this post Link to post Share on other sites
Ed Kennell 47,320 #8 Posted August 24 Interesting build. Looks like both engines are belted to a jack shaft that drives the transmission. Can these engines be reversed? Seems the belts would be too short to reverse by twisting. 1 1 Share this post Link to post Share on other sites
Bar Nuthin 3,225 #9 Posted August 24 I have to admit; I dig that hood ornament! 2 1 Share this post Link to post Share on other sites
953 nut 69,297 #10 Posted August 24 @FLtractor, where do you come up with all of these shall we say INTERESTING Wheel Horses? With the correctly ground cam shaft the engine on the right could be made to turn counterclockwise (flywheel end) like automotive engines that are used as inboard twins. Is such a camshaft commercially available, I doubt it. If both engines ran hydraulic pumps whos rotation matched the engines and their combined output ran a hydraulic motor that powered the trans axle it could be functional. Probably have to add a couple feet to the frame to do that. Guess you could always connect both engines to a jackshaft after removing the pistons and rods from the right side engine allowing the other engine to rotate and make people think it is running backward and come up with a real good story about how you ground your own cam using a Dermal. Share this post Link to post Share on other sites
ebinmaine 80,695 #11 Posted August 24 While looking at gearbox options for Colossus I found that there are options that include a 2 gear, same speed in/out rotation reverser. Someone needs to buy this just so we can disect it. 1 Share this post Link to post Share on other sites
Lee1977 7,772 #12 Posted August 24 The engine on the right could run and not be connected. 1 Share this post Link to post Share on other sites
oldlineman 1,809 #13 Posted August 24 Might be worth the price if both engines are in good running order, and rest of tractor would be parts IMHO. 1 1 Share this post Link to post Share on other sites
Ed Kennell 47,320 #14 Posted August 24 1 hour ago, Lee1977 said: The engine on the right could run and not be connected. Looks like they may be connected to a jack shaft. 3 Share this post Link to post Share on other sites
