Retired Wrencher 6,858 #1 Posted 3 hours ago (edited) I have this B 60 I picked up last weekend. I may have an original engine for it this week end? Will know buy the end of the weekend. It currently has a 8 hp start /gen motor in it now. It runs good. But it is in a tight space. But looking for options. I have seen people use Harbor freight engines in them. With good results I guess? Any other options? I have always like these little B-60’S. Cool and very functional. Reason I picked this up I am try to preserve the 856 I have.It is the best one I currently have. I am restoring an B-100 correctly. Any thoughts are welcome. Edited 3 hours ago by Retired Wrencher 4 Share this post Link to post Share on other sites
ebinmaine 79,887 #2 Posted 3 hours ago My own thoughts... keep it KOHLER powered. Adjust that one with a shorter belt maybe? Definitely insulate those S/G terminal ends from the gas tank spring. That's a serious problem. 1 Share this post Link to post Share on other sites
ebinmaine 79,887 #3 Posted 3 hours ago You could also get the proper type 8 HP engine in there. Easy swap. Share this post Link to post Share on other sites
TonyToro Jr. 2,517 #4 Posted 2 hours ago 13 minutes ago, ebinmaine said: You could also get the proper type 8 HP engine in there. Easy swap. B-60s came factory with a 7hp pull start Kohler not sure if the model. 2 Share this post Link to post Share on other sites
953 nut 67,844 #5 Posted 2 hours ago I'm a firm believer in "If it ain't broke, don't fix it" The voltage regulator could be rotated a bit forward and like @ebinmaine suggested the terminals should be insulated. 1 Share this post Link to post Share on other sites
Pullstart 70,925 #6 Posted 2 hours ago The yank start B-60 has been a desire of mine. Not like I need another worker, but if one landed in my lap I’d probably enjoy it for a while! 1 Share this post Link to post Share on other sites
ebinmaine 79,887 #7 Posted 2 hours ago 1 minute ago, TonyToro Jr. said: B-60s came factory with a 7hp pull start Kohler not sure if the model. I should clarify "proper type". I mean get the S/G out and use a later model smaller starter. That said, I'd really rather see it left as is and insulated. Share this post Link to post Share on other sites
ebinmaine 79,887 #8 Posted 2 hours ago 1 minute ago, Pullstart said: yank start Same here. 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,517 #9 Posted 2 hours ago 3 minutes ago, ebinmaine said: I should clarify "proper type". I mean get the S/G out and use a later model smaller starter. That said, I'd really rather see it left as is and insulated. Oh! Yes I definitely would like to see that S/G stay in. I love the sound of those. 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,517 #10 Posted 2 hours ago 7 minutes ago, Pullstart said: The yank start B-60 has been a desire of mine. Not like I need another worker, but if one landed in my lap I’d probably enjoy it for a while! They are great little tractors! 1 Share this post Link to post Share on other sites
sqrlgtr 3,485 #11 Posted 2 hours ago Looks like a nicely done transplant besides the voltage regulator proximity to fuel tank spring. I would leave it the way it is if it where me unless I was needing the little 8 fer some other project and had the proper Kohler to slide back in its place. No way would I replace a Kohler with a horror freight motor, tecky maybe but not a Kohler. 1 Share this post Link to post Share on other sites
ebinmaine 79,887 #12 Posted 2 hours ago 12 minutes ago, sqrlgtr said: No way would I replace a Kohler with a horror freight motor, Agreed. 12 minutes ago, sqrlgtr said: tecky maybe but not a Kohler. I wouldn't even do that. If I needed to transplant a non Kohler engine, I would find another Kohler instead of using ANY of the "inexpensive imports." Share this post Link to post Share on other sites
sqrlgtr 3,485 #13 Posted 1 hour ago Don't get me wrong I have one predator swap that I done several years ago in a 550 Suburban and have had good luck with it, but if I had it to do over I would have waited and found the proper Tecky or Kohler. There is also a big aftermarket support for the Predators. Pic of 550 with Predator. 2 Share this post Link to post Share on other sites
Goldnboy 1,139 #14 Posted 48 minutes ago (edited) That B60 can easily be converted to a C120, C160 with the drop in of a larger engine.. Remember the 1976-77 series everything was the same on the top of the line models with the exception of Seats, Lights and Hp. Edited 48 minutes ago by Goldnboy 1 Share this post Link to post Share on other sites
ebinmaine 79,887 #15 Posted 46 minutes ago 2 minutes ago, Goldnboy said: everything was the same on the top of the line models with the exception of Seats, Lights and Hp. ..... and steering wheel 1 Share this post Link to post Share on other sites
