Terry M-(Moderator) 2,331 #1 Posted August 14 My last two battery chargers only lasted a few years…those just stopped working. so I’m back to using my 37 year old manual charger to charge my tractor batteries. does anybody make a decent charger for home use anymore?? 1 4 Share this post Link to post Share on other sites
Bar Nuthin 3,639 #2 Posted August 14 (edited) I have an ancient Shumacher 2/10 amp and ancient roll around NAPA 450 amp that just keep on going. I think the NAPA branded one may be made by Shumacher as well. The knobs are off of an old gas grill Edit: I misspoke. The small one is a Schauer. I think it was my Dad’s, and he’s been gone since 1972. Tapering charge. Still works great despite much neglect. Edited August 14 by Bar Nuthin 2 3 Share this post Link to post Share on other sites
CasaytheMann 288 #3 Posted August 14 I recommend getting one that has rejuvination capability. I bought an el cheapo Stanley at Walmart probably 8 years ago. Works great for me. 1 Share this post Link to post Share on other sites
JoeM 10,318 #4 Posted August 14 I like the Viking chargers at Hobo Freight. they even go into winter maintain mode. A little pricey tho. 1 Share this post Link to post Share on other sites
squonk 48,426 #5 Posted August 14 Scour FB MP and garage sales for an old one. I still have my Craftsman from when I got my first car in 76. I use it for my E tank. I did buy one of those Viking Battery jump pack thingy's from HF. Haven't needed to use it yet. 3 Share this post Link to post Share on other sites
953 nut 70,648 #6 Posted August 14 Much like Mike, both of mine are old Craftsman units. The six amp I have had for fifty years or so and the ten amp I bought at a yard sale about twenty years ago, it even has the automatic shut down when the battery is charged. 1 Share this post Link to post Share on other sites
peter lena 10,123 #7 Posted August 14 @Terry M have a small napa charger , as a back up , but my 3 horses , have battery tenders wired in , always a quick simple plug in , like this , last picture , hiding in plane site , pete 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,918 #8 Posted August 14 Several of these. Work great. 4 2 Share this post Link to post Share on other sites
peter lena 10,123 #9 Posted August 14 @SylvanLakeWH thanks for the shout ! , a lot of what I do , is tried , verified for regular function , then TWEEK IT ! make it easier to use , evert stage of this has eliminated repetitive issues , ex , started using sta bil fuel storage AFTER FUEL TANK CLEAN OUT , AND HOSE REPLACEMENT , FILTER NOW AT TANK START AND FILTER AT CARB , WITH FUEL CHECK VALVE ? SHORT CLEAN FUEL RATED HOSE TO CARB? LOOKING AT CLEAN FUEL HOLD TO CLEAN CARB BOWL. , guess what ? NEVER HAD ANY DEBRIS RETURN , STOPPED A CHRONIC ISSUE ! 3 horses with same set ups , move on to next issue , pete 1 Share this post Link to post Share on other sites
davem1111 2,453 #10 Posted August 14 1 hour ago, peter lena said: @Terry M have a small napa charger , as a back up , but my 3 horses , have battery tenders wired in , always a quick simple plug in , like this , last picture , hiding in plane site , pete I have one of those battery tender plug-ins on my motorcycle, hadn't thought about putting them on the tractors but that's a great idea. I think I'll get a few more tenders so I have enough for each and don't have to remember to move them around periodically in the winter. But sometimes I remove the batteries and bring them in the house, like when it's going to be say, below 20 degrees (or worse) for several days or more. 2 Share this post Link to post Share on other sites
lynnmor 9,081 #11 Posted August 14 1 hour ago, SylvanLakeWH said: Several of these. Work great. I have two 1.25 amp and one .75 amp Battery Tenders, I just don't trust most of the cheap stuff out there. I rotate the chargers among six tractors, two trailers, one mower and one motorcycle, leaving each attached about 3 days per month. 2 Share this post Link to post Share on other sites
Achto 32,962 #12 Posted August 14 I like the older Schumacher chargers. @WHX??will attest to the fact that I will run over the top of some one at a flea market in order to get one. What I like about them is that they will actually change a dead battery. No BS electronics to screw up the process. 1 2 Share this post Link to post Share on other sites
953 nut 70,648 #13 Posted August 14 I have always believed that running each at least once a month cycles the battery which is better for them than just being on a tender. All critical equipment at the power plant was powered from inverters powered by battery banks. Each week one battery bank was placed on a load to draw them down to 80% voltage and then recharged prior to being placed in service. Each cell would be tested before and after and any that didn't pass the test had to be replaced. We seldom had to replace one. 3 2 Share this post Link to post Share on other sites
