pfrederi 20,952 #1 Posted 9 hours ago (edited) Picked up a GT-1848 last year for cheap at auction as she didn't run...Turns out those B&S engines actually require fuel mixture to run. After going over the flue system she worked great. The hydro engagement lever shook around and rattled a lot. Part of problem was drive belt was missing a couple chunks...but even with a new belt lots more rattle and noise than my 418A. My older Sustrands also rattle and I have replaced the wave washers with not much improvement. (Use a small bungee cord on one to quiet it down) So why is the 418 quiet but not the GT same system right??? Wrong...WH made a change in the later hydros and added an anti rattle spring instead of using wave washers. Looked at the spring on my 418 and went to my box of springs found one that was actually for some WH snow blower that looked close. Shortened and bent the end loops put it on the GT and voila quieter. As the other Sunstrands come in for maintenance going to fix them up as well. First diagram GT 2nd 418 note #29 WH part 107938 First pic 418 2nd GT Edited 9 hours ago by pfrederi 4 3 Share this post Link to post Share on other sites
squonk 47,499 #2 Posted 8 hours ago I've welded up the worn pivot points to stop rattles as well. 1 Share this post Link to post Share on other sites
peter lena 9,979 #3 Posted 8 hours ago @pfrederi don't have one of those but sure can relate ! horses are known for glairing linkage / lever set ups , based on penny pinching , and lack of FUNCTIONAL DETAILING . of course have to throw in a sealed idler belt pulley ! typically belts show you the way ? , frayed , cracked from incremental sealed bearing lubrication ? starts belt bounce , as bearing hangs up / stops . my experience , is touching each stage of hand off , verify / enhance , penetrant gets the rust flowing , then aerosol red grease , added washers , to enhance action , love those hook end , light to medium springs . done similar on , pto lever set up , and plow swing quadrant , lever set up , amazing transformation , functional ease . done a lot of mods to my horses , can't even see them , but you sure can feel / sense them! related belt wear , is telling you what's happening , would love to do one of those , pete Share this post Link to post Share on other sites
ebinmaine 79,821 #4 Posted 4 hours ago Interesting fix. Share this post Link to post Share on other sites
