1054 Project
1054 Hydraulic Cylinder Not Functioning
1054 Project
1054 with 5248 hydraulic assembly (model # A4CCWH pump). Cylinder is not moving either direction. Fluid level is good, pulley is turning fine.
peter lena
adsm08
It's a pretty simple system.
If the fluid level is correct, and the pulley SHAFT is spinning, I'd start by disconnecting the rock shaft from the ram and see if the ram can be moved by hand. If so it is likely to have bad seals inside and is in full bypass.
953 nut
:text-yeahthat:
When you operate the lever on the pump does it grunt or make any noise in either direction?
Your cylinder is a DOUBLE ACTING cylinder. with pressure applied to one end the fluid in the other end of the cylinder will be pushed back to the pump reservoir. If your cylinder is the welded type as shown then it can be rebuilt by @wheelhorseman, here is a link to his store.https://wheelhorsepartsandmore.com/product/welded-cylinder-repair/. Lowell also has hoses and pump kits.
1054 Project
1054 Project
12 hours ago, 953 nut said:
:text-yeahthat:
Great info. Thanks!
1054 Project
Its usually he simple stuff that I struggle with! Thanks for the advice, I'll give it a try.
1054 Project
3 minutes ago, 1054 Project said:
Great info. Thanks!
Also, no strange noises.
adsm08
Look, I spent months trying to figure out why mine would go one way and not the other before I figured out that I didn't drive a roll pin in the whole way (on purpose, for testing) and the return spring was catching on it.
  • Haha 1
953 nut
:confusion-confused:           If the cylinder isn't moving but the pump is developing pressure I would expect there would be some sound difference when the up-down lever is moved.
sqrlgtr
I just knew my pump was going bad once but I had left the pulley loose and it would spin on shaft, but sometimes it wouldn't spin on shaft and would work fine. I couldn't figure out why it would work great sometimes, sometimes wouldn't work and sometimes it would be slow, I finally noticed the pulley walking in and out on shaft and had enough since to tighten it up. Mine also never made any weird noises. Hopefully yours will be sumin simple too. I did change fluid in mine thinking it might help so at least sumin good did come out of it :D.
1054 Project
Takes a great deal of effort to pull the ram out (both hands and some grunting). Slightly less effort to push the ram back in.
adsm08
That is a good sign. It means that it's probably not internally bypassed (seals not blown out).
I guess the next thing to do would be to get the lines loose and into a container of some sort and check for flow.
Pro tip: You can remove the pulley, chuck it in a cordless drill, and have a lot more control than trying to do these tests with the engine driving the pump.
1054 Project
Yep that's the next step. Thanks for the tip! By the way what do you recommend for hyd. fluid. I've been using ATF.
adsm08
I, and at least a few others here, have been using Type F transmission fluid.
953 nut
:text-yeahthat:
1054 Project
Well that was interesting  :huh:. I couldn't take advantage of your pro tip because my drills are both 3/8" and it looks like I would need a 1/2" chuck. So once I managed to disconnect the cylinder I directed the hose ends towards my oil change pan and start the tractor. My logic was if I start the engine with the control handle in the neutral position I would have control of the process. I was wrong (so much for logic). Within 3 seconds (not an exaggeration) I had fluid all over the place! Not sure what that tells me about the issue at hand but I'll need to get out and purchase more fluid before I can take further action.
Bar Nuthin
Sounds like your spool valve may be the issue. I wouldn't think it should push fluid in the neutral position. But I don't have any experience with that style pump.
Edited by Bar Nuthin
1054 Project
I tend to agree. I think the spool valve may be stuck in the fully retracted (regardless of the position of the lift lever) which could mimic a non-functioning cylinder. Not sure what the fix would be. :confusion-confused:
adsm08
If the spool valve is in the neutral position there should be no fluid flow from either hose.
Now, since the fluid has already escaped, and the hoses are disconnected, you can GENTLY use compressed air into the ports to check the function of  the lift ram.
The other potential possibility here is that the pump is worn. It is very possible that the pump is able to produce flow, but not enough pressure to operate the lift.
Remove plug #4 and inspect spring #3 and check ball #2. Those should be the components that provide the restriction that allows the pump to build pressure. I have taken apart a few of these and seen at least one of them with those items stuck.
Edited by adsm08
adsm08
This is physically impossible. The handle is bolted directly to the valve, if one moves so does the other.
Edited by adsm08
