1054 Project
1054 Hydraulic Cylinder Not Functioning
1054 Project
1054 with 5248 hydraulic assembly (model # A4CCWH pump). Cylinder is not moving either direction. Fluid level is good, pulley is turning fine.
peter lena
adsm08
It's a pretty simple system.
If the fluid level is correct, and the pulley SHAFT is spinning, I'd start by disconnecting the rock shaft from the ram and see if the ram can be moved by hand. If so it is likely to have bad seals inside and is in full bypass.
953 nut
:text-yeahthat:
When you operate the lever on the pump does it grunt or make any noise in either direction?
Your cylinder is a DOUBLE ACTING cylinder. with pressure applied to one end the fluid in the other end of the cylinder will be pushed back to the pump reservoir. If your cylinder is the welded type as shown then it can be rebuilt by @wheelhorseman, here is a link to his store.https://wheelhorsepartsandmore.com/product/welded-cylinder-repair/. Lowell also has hoses and pump kits.
1054 Project
1054 Project
12 hours ago, 953 nut said:
:text-yeahthat:
Great info. Thanks!
1054 Project
Its usually he simple stuff that I struggle with! Thanks for the advice, I'll give it a try.
1054 Project
3 minutes ago, 1054 Project said:
Great info. Thanks!
Also, no strange noises.
adsm08
Look, I spent months trying to figure out why mine would go one way and not the other before I figured out that I didn't drive a roll pin in the whole way (on purpose, for testing) and the return spring was catching on it.
953 nut
:confusion-confused:           If the cylinder isn't moving but the pump is developing pressure I would expect there would be some sound difference when the up-down lever is moved.
sqrlgtr
I just knew my pump was going bad once but I had left the pulley loose and it would spin on shaft, but sometimes it wouldn't spin on shaft and would work fine. I couldn't figure out why it would work great sometimes, sometimes wouldn't work and sometimes it would be slow, I finally noticed the pulley walking in and out on shaft and had enough since to tighten it up. Mine also never made any weird noises. Hopefully yours will be sumin simple too. I did change fluid in mine thinking it might help so at least sumin good did come out of it :D.
