1054 Project 94 #1 Posted August 8 1054 with 5248 hydraulic assembly (model # A4CCWH pump). Cylinder is not moving either direction. Fluid level is good, pulley is turning fine. Share this post Link to post Share on other sites
peter lena 10,065 #2 Posted August 8 @1054 Project might uses this as a basic look up , maybe find good ( verified ) unit , https://www.google.com/search?q=typical+issue+with+hydraulic+valves&rlz=1C1CHBF_enUS866US866&oq=typical+issue+with++hydraulic+valves+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigATIHCAIQIRigATIHCAMQIRiPAjIHCAQQIRiPAtIBCTI1MjU2ajFqNKgCAbACAfEFG4MOMfuiJYfxBRuDDjH7oiWH&sourceid=chrome&source=chrome.ob&ie=UTF-8 . pete Share this post Link to post Share on other sites
adsm08 5,145 #3 Posted August 8 It's a pretty simple system. If the fluid level is correct, and the pulley SHAFT is spinning, I'd start by disconnecting the rock shaft from the ram and see if the ram can be moved by hand. If so it is likely to have bad seals inside and is in full bypass. 1 Share this post Link to post Share on other sites
953 nut 69,285 #4 Posted August 9 When you operate the lever on the pump does it grunt or make any noise in either direction? Your cylinder is a DOUBLE ACTING cylinder. with pressure applied to one end the fluid in the other end of the cylinder will be pushed back to the pump reservoir. If your cylinder is the welded type as shown then it can be rebuilt by @wheelhorseman, here is a link to his store.https://wheelhorsepartsandmore.com/product/welded-cylinder-repair/. Lowell also has hoses and pump kits. Share this post Link to post Share on other sites
1054 Project 94 #5 Posted August 9 17 hours ago, peter lena said: @1054 Project might uses this as a basic look up , maybe find good ( verified ) unit , https://www.google.com/search?q=typical+issue+with+hydraulic+valves&rlz=1C1CHBF_enUS866US866&oq=typical+issue+with++hydraulic+valves+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigATIHCAIQIRigATIHCAMQIRiPAjIHCAQQIRiPAtIBCTI1MjU2ajFqNKgCAbACAfEFG4MOMfuiJYfxBRuDDjH7oiWH&sourceid=chrome&source=chrome.ob&ie=UTF-8 . pete Thank you. This may help. 1 Share this post Link to post Share on other sites
1054 Project 94 #6 Posted August 9 12 hours ago, 953 nut said: When you operate the lever on the pump does it grunt or make any noise in either direction? Your cylinder is a DOUBLE ACTING cylinder. with pressure applied to one end the fluid in the other end of the cylinder will be pushed back to the pump reservoir. If your cylinder is the welded type as shown then it can be rebuilt by @wheelhorseman, here is a link to his store.https://wheelhorsepartsandmore.com/product/welded-cylinder-repair/. Lowell also has hoses and pump kits. Great info. Thanks! 1 Share this post Link to post Share on other sites
1054 Project 94 #7 Posted August 9 15 hours ago, adsm08 said: It's a pretty simple system. If the fluid level is correct, and the pulley SHAFT is spinning, I'd start by disconnecting the rock shaft from the ram and see if the ram can be moved by hand. If so it is likely to have bad seals inside and is in full bypass. Its usually he simple stuff that I struggle with! Thanks for the advice, I'll give it a try. Share this post Link to post Share on other sites
1054 Project 94 #8 Posted August 9 3 minutes ago, 1054 Project said: Great info. Thanks! Also, no strange noises. 1 Share this post Link to post Share on other sites
adsm08 5,145 #9 Posted August 9 9 minutes ago, 1054 Project said: Its usually he simple stuff that I struggle with! Thanks for the advice, I'll give it a try. Look, I spent months trying to figure out why mine would go one way and not the other before I figured out that I didn't drive a roll pin in the whole way (on purpose, for testing) and the return spring was catching on it. 1 Share this post Link to post Share on other sites
953 nut 69,285 #10 Posted August 9 10 hours ago, 1054 Project said: Also, no strange noises. If the cylinder isn't moving but the pump is developing pressure I would expect there would be some sound difference when the up-down lever is moved. Share this post Link to post Share on other sites
sqrlgtr 3,927 #11 Posted August 10 I just knew my pump was going bad once but I had left the pulley loose and it would spin on shaft, but sometimes it wouldn't spin on shaft and would work fine. I couldn't figure out why it would work great sometimes, sometimes wouldn't work and sometimes it would be slow, I finally noticed the pulley walking in and out on shaft and had enough since to tighten it up. Mine also never made any weird noises. Hopefully yours will be sumin simple too. I did change fluid in mine thinking it might help so at least sumin good did come out of it . 1 Share this post Link to post Share on other sites
1054 Project 94 #12 Posted August 10 On 8/8/2026 at 6:11 PM, adsm08 said: It's a pretty simple system. If the fluid level is correct, and the pulley SHAFT is spinning, I'd start by disconnecting the rock shaft from the ram and see if the ram can be moved by hand. If so it is likely to have bad seals inside and is in full bypass. Takes a great deal of effort to pull the ram out (both hands and some grunting). Slightly less effort to push the ram back in. 1 Share this post Link to post Share on other sites
adsm08 5,145 #13 Posted August 11 7 hours ago, 1054 Project said: Takes a great deal of effort to pull the ram out (both hands and some grunting). Slightly less effort to push the ram back in. That is a good sign. It means that it's probably not internally bypassed (seals not blown out). I guess the next thing to do would be to get the lines loose and into a container of some sort and check for flow. Pro tip: You can remove the pulley, chuck it in a cordless drill, and have a lot more control than trying to do these tests with the engine driving the pump. 1 Share this post Link to post Share on other sites
1054 Project 94 #14 Posted August 11 11 hours ago, adsm08 said: That is a good sign. It means that it's probably not internally bypassed (seals not blown out). I guess the next thing to do would be to get the lines loose and into a container of some sort and check for flow. Pro tip: You can remove the pulley, chuck it in a cordless drill, and have a lot more control than trying to do these tests with the engine driving the pump. Yep that's the next step. Thanks for the tip! By the way what do you recommend for hyd. fluid. I've been using ATF. Share this post Link to post Share on other sites
adsm08 5,145 #15 Posted August 11 8 hours ago, 1054 Project said: Yep that's the next step. Thanks for the tip! By the way what do you recommend for hyd. fluid. I've been using ATF. I, and at least a few others here, have been using Type F transmission fluid. Share this post Link to post Share on other sites
1054 Project 94 #17 Posted August 12 17 hours ago, adsm08 said: I, and at least a few others here, have been using Type F transmission fluid. Well that was interesting . I couldn't take advantage of your pro tip because my drills are both 3/8" and it looks like I would need a 1/2" chuck. So once I managed to disconnect the cylinder I directed the hose ends towards my oil change pan and start the tractor. My logic was if I start the engine with the control handle in the neutral position I would have control of the process. I was wrong (so much for logic). Within 3 seconds (not an exaggeration) I had fluid all over the place! Not sure what that tells me about the issue at hand but I'll need to get out and purchase more fluid before I can take further action. Share this post Link to post Share on other sites
Bar Nuthin 3,222 #18 Posted August 12 (edited) 31 minutes ago, 1054 Project said: Not sure what that tells me about the issue at hand but I'll need to get out and purchase more fluid before I can take further action. Sounds like your spool valve may be the issue. I wouldn't think it should push fluid in the neutral position. But I don't have any experience with that style pump. Edited August 12 by Bar Nuthin Share this post Link to post Share on other sites
1054 Project 94 #19 Posted August 12 3 hours ago, Bar Nuthin said: Sounds like your spool valve may be the issue. I wouldn't think it should push fluid in the neutral position. But I don't have any experience with that style pump. I tend to agree. I think the spool valve may be stuck in the fully retracted (regardless of the position of the lift lever) which could mimic a non-functioning cylinder. Not sure what the fix would be. Share this post Link to post Share on other sites
adsm08 5,145 #20 Posted August 13 (edited) If the spool valve is in the neutral position there should be no fluid flow from either hose. Now, since the fluid has already escaped, and the hoses are disconnected, you can GENTLY use compressed air into the ports to check the function of the lift ram. The other potential possibility here is that the pump is worn. It is very possible that the pump is able to produce flow, but not enough pressure to operate the lift. Remove plug #4 and inspect spring #3 and check ball #2. Those should be the components that provide the restriction that allows the pump to build pressure. I have taken apart a few of these and seen at least one of them with those items stuck. Edited August 13 by adsm08 1 Share this post Link to post Share on other sites
adsm08 5,145 #21 Posted August 13 (edited) 7 hours ago, 1054 Project said: I think the spool valve may be stuck in the fully retracted (regardless of the position of the lift lever) This is physically impossible. The handle is bolted directly to the valve, if one moves so does the other. Edited August 13 by adsm08 Share this post Link to post Share on other sites
1054 Project 94 #22 Posted August 13 10 hours ago, adsm08 said: This is physically impossible. The handle is bolted directly to the valve, if one moves so does the other. I'm probably over my depth here but something is allowing fluid to be forcefully expelled from the pump with the cylinder removed and the control in neutral. Share this post Link to post Share on other sites
1054 Project 94 #23 Posted August 13 10 hours ago, adsm08 said: If the spool valve is in the neutral position there should be no fluid flow from either hose. Now, since the fluid has already escaped, and the hoses are disconnected, you can GENTLY use compressed air into the ports to check the function of the lift ram. The other potential possibility here is that the pump is worn. It is very possible that the pump is able to produce flow, but not enough pressure to operate the lift. Remove plug #4 and inspect spring #3 and check ball #2. Those should be the components that provide the restriction that allows the pump to build pressure. I have taken apart a few of these and seen at least one of them with those items stuck. I'll be out of town next week but will troubleshoot the relief valve when I return. Share this post Link to post Share on other sites
1054 Project 94 #24 Posted September 1 I found the issue! There are 2 screws that attach the lift handle to the pump (spool valve). One of the screws was gone so moving the handle was not moving the spool. Thanks to all that responded to this post! I now have another pump related question but will start a new thread for that. 1 Share this post Link to post Share on other sites
