rustyedge1
Whee Horse 102742 belts wearing poorly. Advice on better made ones.
rustyedge1
Belt in photo is K Force brand A 102742 which is what my local parts place is pushing at 30 bucks plus.
This one was bought two seasons ago counting this mowing season and it’s not going to make it looks like..
Any info on better made belts appreciated..IMG_0328.jpeg.3c073cc52ba0f4bcb033ae50844e9002.jpeg
gwest_ca
You could try a Gates or Napa 6378 made to replace the original 102742
Ed Kennell
TSC Aramid blue belts are my go to.
Image showing Huskee Huskee 0.5 in. x 105 in. Blue Aramid V-Belt
peter lena
@rustyedge1 bet ya dollars to donuts , its  lubrication  failure related , from that pto cone inner needle bearing , to every  related belt / pulley set up , pulleys are probably  rough , noisy , COMBINED  INCREMENTAL  LUBRICATION FAILURE  , CREATES  BELT BOUNCE / WHINE, STOPAGE ,  would also not  be surprised if the pto lever start  area is also hanging up , increasing initial function  drag . what does it sound like ?   buzzing , vibratition  , you need  more than belts , pete
  • Like 5
Bill D
My local Lowes has the same blue belts as TSC, just different packaging.  They have every deck size I need except the 86" for the 42" SD deck.
rustyedge1
Thanks all. Have a TSC just down the road believe I’ll try a blue one this time.
The mule drive pulleys seem to be solid and turning freely. Deck spindles all solid but it’s an old Horse
correction made, thanks.
Edited by rustyedge1
953 nut
FYI, the belt should be on the larger PTO pulley for mowing.
512187943_Screenshot(694).png.65f432c7659a2af2f55ef9853f679507.png440133442_Screenshot(695).png.f0ff0fb4681eaae63f9a9e8c652d2e8c.png
  • Like 4
c-series don
Yes, the inside pulley will increase your blade speed.
My_horse
That’s funny, the previous owner of my 314-8 had the belt on the smaller pulley. Couldn’t understand why it didn’t cut so good. I figured it out eventually.
squonk
I sold belts for 10 years. Usually belts even the cheap ones don't fall apart like that. Most of the time it's an alignment/sharp edge issue, or a bearing issue. The bearings may seem fine but put a load on them and they start seizing up. My first guess is a weak deck shell causing an alignment problem
peter lena
@rustyedge1  let me understand ?  you have the best belt  , in the WRONG  DRIVE  PULLEY ?  inner  pulleys , increase speed  , torque and  movement start ? what is stopping you from doing this ? another vital part of my set ups is a roller stool  look around at  every stage , so you can INSURE MOVEMENT HAND OFF , TO NEXT STAGE . DO A LOT OF THAT ? VERIFY HOW THINGS OPERATE ! BTW   also enhanced the  lever trundle end to a heim joint , and added a  spring pull to end of , pto swing arm clip to frame ? enhances function and stops  buzzing , this is easy , pete
peter lena
@rustyedge1  some ideas incorporated  into my 3 horses , BASED ON REPEDITIVE FAILURE , years in use , no issues , pete
953 nut
I had this years ago but the drive belt just kept coming off, didn't harm the belt.  Weld up the cracks and problem solved.
  • Similar Content
    • River Rat
      By River Rat
      I am looking for the Wheel Horse part number for the Mule Drive belt on my 1984 C145A 11-14KE01. I believe it is 102742. The old one is stretched quite a bit and not sure the outside length. possibly 1/2 by 103 in? 48 inch mower.
      Any help is appreciated!
    • Gettysburg Axel
      By Gettysburg Axel
      In search of a mule drive for a 60 inch deck for my 520. Located near central Pa or able to ship if possible. Also would be interested in trading parts for the mule drive if wanted.
    • 87 312-8
      By 87 312-8
      looking for mule drive bearings for a 36 inch rear discharge deck 1986/87 312-8, thank you
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • ryobi.warrior
      By ryobi.warrior
      The belt on my Wheel Horse 314-8 mower deck (05-37SC01) appears to be contacting the deck bracket between the spindle pulleys. I am a novice when it comes to Wheel Horse maintenance (at best), but this does not seem correct.
      I recently inherited this Wheel Horse, so I do not know the maintenance history. Unfortunately, the mechanic who previously worked on it was a no-show for a scheduled maintenance visit.
      Any advice on how to address this? Thanks in advance... this seems like a great forum and I'm looking forward to spending time here!
      Photos (please forgive the dirt and grime, I plan to clean it up!): https://imgur.com/a/4PknZuJ
