AHS 1,698 #1 Posted August 4 I am helping a guy fix the loader. Bill, ( my friend w/ the GT550) bought it yesterday. The loader is quirky! I told him to check the hydro fluid. Once you pull the PTO switch; 90% of the time the loader will do nothing. The other 10% of the time it will lift the bucket. The old WH dealer has been around the GT550, and he says the GT550 needs a pump. (And they don’t make the pump anymore). So, what do you guys use for a pump? Any questions, please ask. Share this post Link to post Share on other sites
953 nut 68,769 #2 Posted August 4 @JoeM probably can help you out. 1 Share this post Link to post Share on other sites
Handy Don 17,372 #3 Posted August 5 (edited) 2 hours ago, AHS said: the GT550 needs a pump. The built-in hydaulic for a GT550 is the charge pump for the Eaton 1100. Same as for most other hydro WHs of that era. Using that pump for a loader’s hydraulics would’ve required some knowledgeable messing with the stock plumbing and still has serious limitations. Too complicated and too many possibilities for a simple thread but the gist is that that pump has neither sufficient volume nor sufficient pressure to properly operate the large cylinders of that loader. That’s why an external pump, usually actuated by the PTO is the norm. (ARE YOU POSITIVE there isn’t one, because it sure looks to me like the plumbing is connecting to something behind the front grille.) If you can, do some tracing/photos of the hydraulic plumbing where it connects to/from the control valves and to/from bottom of the fluid reservoir in the left side sub-frame upright member and let us know. PM me and we can speak if that helps. Edited August 5 by Handy Don 1 Share this post Link to post Share on other sites
Bill D 3,119 #4 Posted August 5 Is it really the pump, or is the electric PTO clutch bad? My money's on the clutch. 2 Share this post Link to post Share on other sites
oliver2-44 11,708 #5 Posted August 5 3 hours ago, AHS said: The left vertical post of the loader is the hydraulic reservoir. In the 1st picture you can see the suction hose that goes to the pump at the bottom the upright. In the 2nd picture you can see a galvanized pipe cap that is the fill, I don't see where you check the level When it does nothing, do you hear hydraulic fluid gargling like the pump is loosing suction, or any difference in noise from when it works and when it doesn't. Does the system have a pressure gauge, or a place to install one? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,478 #6 Posted August 5 The 2005 550 was a 522xi in 2004 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #7 Posted August 5 The pump for the loader is belt-drive. Has anyone actually checked the belt? You'll find a lot of helpful info in this thread: 1 1 Share this post Link to post Share on other sites
AHS 1,698 #8 Posted August 5 @oliver2-44 I don’t know where a pressure gauge would go. It’s nice to have a pressure gauge! Where would a pressure gauge go? Fill and 516” check plug, that’s all, right? Share this post Link to post Share on other sites
AHS 1,698 #9 Posted August 5 So, what i got is; start the tractor, put the parking brake on, put the PTO on and look under there and see if the belt is moving or the clutch is bad. 1 2 Share this post Link to post Share on other sites
peter lena 10,029 #10 Posted August 5 @AHS hydraulics can quickly OVERWHELM A REGULAR PRESSED FRAMEWORK , look for related spider cracking , sloppy engagement areas . maybe remove some paneling for a related movement area ? also bad clutch indicates , excessive loading , examine every stage of INTENDED MOVEMENT , probably show you the way , [ete 1 Share this post Link to post Share on other sites
Handy Don 17,372 #11 Posted August 5 (edited) 3 hours ago, AHS said: The cap also vents the reservoir because its fluid level changes significantly due to the difference in each cylinder's fluid volume between extended and retracted. 3 hours ago, AHS said: I don’t know where a pressure gauge would go A pressure gauge would be at the output side of the pump. That said, understand that the pump runs constantly (once engaged) but builds significant pressure only when actuating a cylinder against resistance (e.g. lifting the bucket). Thus, the reading would vary a lot! Edited August 5 by Handy Don 1 Share this post Link to post Share on other sites
AHS 1,698 #12 Posted August 5 @Handy Don Yes!! I forgot about that!! Wait a minute!! Upon looking at the tractor; i thought that’s an odd looking cap. What if someone had switched the caps… and it’s a solid cap. No air hole or nothing! Would that make it do what its doing? Share this post Link to post Share on other sites
Handy Don 17,372 #13 Posted August 5 56 minutes ago, AHS said: @Handy Don Yes!! I forgot about that!! Wait a minute!! Upon looking at the tractor; i thought that’s an odd looking cap. What if someone had switched the caps… and it’s a solid cap. No air hole or nothing! Would that make it do what its doing? Not venting the reservoir will cause issues. Try removing it and covering with something to keep bugs & dirt out like a filter cloth. 2 Share this post Link to post Share on other sites
JCM 11,403 #14 Posted August 5 My Kwik- Way loader I bought with around 20 hours on it. I believe mine had a black plastic cap with possibly a vent hole in it from the factory. I have pics but not sure you can see a hole / vent ? It also called for ATF Fluid. 1 Share this post Link to post Share on other sites
JCM 11,403 #15 Posted August 5 (edited) Right below the 2 levers is the vent cap / fill. Edited August 5 by JCM 1 Share this post Link to post Share on other sites
lynnmor 9,022 #16 Posted August 5 On 8/4/2026 at 6:35 PM, AHS said: I am helping a guy fix the loader. Bill, ( my friend w/ the GT550) bought it yesterday. The loader is quirky! I told him to check the hydro fluid. Once you pull the PTO switch; 90% of the time the loader will do nothing. The other 10% of the time it will lift the bucket. The old WH dealer has been around the GT550, and he says the GT550 needs a pump. (And they don’t make the pump anymore). So, what do you guys use for a pump? Any questions, please ask. I bought a pump from Northern Hydraulics since the original was NLA. Find the specifications for the original and buy the one that is close. 1 Share this post Link to post Share on other sites
AHS 1,698 #17 Posted August 8 @lynnmor whats the GPM of the pump? Share this post Link to post Share on other sites
lynnmor 9,022 #18 Posted August 8 2 hours ago, AHS said: @lynnmor whats the GPM of the pump? I found the brand and model number on the pump and googled it, I don't remember the numbers. Here is some discussion that might help. Share this post Link to post Share on other sites
wallfish 20,547 #19 Posted August 8 https://www.northerntool.com/products/concentric-high-pressure-hydraulic-gear-pump-0-517-cu-in-model-g1232c5a300n00-10567 GPM can be fine tune adjusted by the speed of the engine and different size pulleys 1 Share this post Link to post Share on other sites
Bill D 3,119 #20 Posted August 9 Lots of pumps at Surplus Center. Look there if interested. 2 Share this post Link to post Share on other sites
OoPEZoO 609 #21 Posted August 10 Another note about the 5xi tractors and the electric PTO.......if your battery/charging system is weak, the PTO is the first thing to not work correctly. For instance, I picked up my 522xi with a 2-stage snow blower on it. Everything worked fine until I actually tried to use it. Every time I would try and plow snow with it, the PTO would shut off and the auger would stop. Cycle it OFF/ON, work fine, pull forward into snow and it would shut off again. Turns out it was a weak battery. Simple fix, but was a head scratcher for awhile as everything seemed fine. Not saying its your same issue, but something to keep in mind if it helps 1 Share this post Link to post Share on other sites
AHS 1,698 #22 Posted August 13 On 8/10/2026 at 1:30 PM, OoPEZoO said: Another note about the 5xi tractors and the electric PTO.......if your battery/charging system is weak, the PTO is the first thing to not work correctly. For instance, I picked up my 522xi with a 2-stage snow blower on it. Everything worked fine until I actually tried to use it. Every time I would try and plow snow with it, the PTO would shut off and the auger would stop. Cycle it OFF/ON, work fine, pull forward into snow and it would shut off again. Turns out it was a weak battery. Simple fix, but was a head scratcher for awhile as everything seemed fine. Not saying its your same issue, but something to keep in mind if it helps Wow!! Share this post Link to post Share on other sites
AHS 1,698 #23 Posted August 13 I think i have everything, lots of notes! Thank you!!! Share this post Link to post Share on other sites
Handy Don 17,372 #24 Posted August 13 On 8/10/2026 at 1:30 PM, OoPEZoO said: Turns out it was a weak battery. Good sleuthing! A depleted battery can completely consume the stator's output without charging and at the same time leave insufficient “juice” (i.e. the 2-4 amps) needed to keep the electric PTO clutch fully engaged. 1 Share this post Link to post Share on other sites
