953 nut 68,743 #26 Posted August 2 8 hours ago, ineedanother said: Many here know better than me, but IMO the 10 pinion with the cast iron end plates and the 1 1/8" axles is the optimal worker. I have both and have no complaints but traction is incomparable between the two IMO. It probably depends on what your needing. The 8-pinions are work horses and don't ever seem to break but the early 10-pinions have. I've worked mine pretty hard and haven't broken either one. Attention to properly installing and maintaining the axle hubs is a high priority in my book regardless of the gearbox you choose. My GT-14 had a transplant going from aluminum to cast iron end plates a few years ago when I replaced an axle I snapped of while it still had the aluminum plates, that is when I discovered the Torrington B-348 bearing deal that took place in '70. I have a 418-C which has an Eaton 1100 and 8 pinion differential that I plow snow with and the GT-14 with the ten pinion limited slip with a new spring that has a loader. The amount of wheel spin on the two is about the same, nearly nonexistent. The GT-14 has over 100 pounds of weights per tire, liquid filled tires and chains. The 418 has 80 pounds of weight per tire, liquid filled tires and chains. I have never had a problem with the 10 pinion but I understand that the people who do pulling tractors prefer the eight pinion for their durability. 1 1 Share this post Link to post Share on other sites
953 nut 68,743 #27 Posted August 2 (edited) 19 hours ago, stevasaurus said: I would call your differential a "Bevel Gear Differential". I have no idea if an 8 pinion differential will be replacable in your trans. It is the same "bevel gear differential" as was used ion the 953. I have had all three, bevel, 8 pinion, and ten pinion on the bench side by side before and all three measured the same and would interchange. Wish I could find the pictures. You know, if you don't have pictures it didn't happen. I memory serves me right the bolts on the bevel gear had to go in a particular direction to work in an eight speed but would clear in either direction in the six speed. BUT, that shouldn't be an issue in the hydro so pardon my getting slightly Have I sufficiently confused the issue? Edited August 2 by 953 nut 1 Share this post Link to post Share on other sites
kb65 14 #28 Posted August 2 so you think the 8 gets the same traction as the 10? I run 62 lb home made lead weights in each wheel and used tires loaded with rv antifreeze in the past. I have had some traction issues as i have some steep hills i need to mow Share this post Link to post Share on other sites
kb65 14 #29 Posted August 2 I cannot seam to find any info as to what diff was used in the hydros in what models / years Share this post Link to post Share on other sites
pfrederi 21,091 #30 Posted August 2 (edited) 1 hour ago, kb65 said: I cannot seam to find any info as to what diff was used in the hydros in what models / years The surest way is to look up the model number of the potential donor and check the parts listing. And that assumes it was not transplanted at some point To add to the confusion if you want to put an 8 pinion into a 10 pinion tranny you have to make sure you have the 2 piece mushroom gear Edited August 2 by pfrederi 2 Share this post Link to post Share on other sites
953 nut 68,743 #31 Posted August 2 (edited) 2 hours ago, kb65 said: I cannot seam to find any info as to what diff was used in the hydros in what models / years You would probably need to go through the IPLs for various models and compare part numbers for axle bearings and case halves and I'm not sure that this would give conclusive results. I have never attempted to swap out the differentials from the Eaton with those from manual or Sundstrand transaxles. It appeared that the Eaton's differential was not replaceable by other earlier units. I have placed the geared transmission's eight pinion in a Sundstrand just for proof of concept. I have also used the bevel gear in a six speed with good results. 2 hours ago, kb65 said: so you think the 8 gets the same traction as the 10? I run 62 lb home made lead weights in each wheel and used tires loaded with rv antifreeze in the past. I have had some traction issues as i have some steep hills i need to mow Mowing very steep grades is never a pleasure, I mowed for my neighbor while he was recouping from surgery and could mow UP the steepest part with my 310-8 4 Pinion open differential without a problem if the grass was DRY but would loose traction going down, one wheel would skid while the other freewheeled. I put on tire chains and had no wheel spin in the steepest places and if you don't spin the wheels the chains don't harm the lawn. My 1055 is also a four pinion open differential with chains, loaded tires and about 40 pounds of weight. It will plow up my driveway with a bit of wheel spin whereas the 418-C will do it without wheel spin but the 418-C had 10.5 " tires and the 1055 only has 8.00" tires. Edited August 2 by 953 nut 1 Share this post Link to post Share on other sites
Handy Don 17,370 #32 Posted August 2 9 minutes ago, 953 nut said: I put on tire chains and had no wheel spin in the steepest places and if you don't spin the wheels the chains don't harm the lawn. I have found the same so I leave the chains on in spring when the lawn is often wet and soft. I do have to be careful that the chains are very snug to the tire else they clatter against the 36” RD gear deck. Short frame tractors don’t have any spare wheelbase! 1 Share this post Link to post Share on other sites
pfrederi 21,091 #33 Posted August 2 Transaxle case numbers are different between your unit and the later hydro gears. And hydro gear case number for left side are different than later piston to piston units.. It might be easier to p[ck up a transaxle from any sunstrand hydro gear. (Chargers Electros etc).. Your hydro pump will bolt on to it. 1 1 1 Share this post Link to post Share on other sites
sqrlgtr 3,776 #34 Posted August 2 12 hours ago, ineedanother said: Many here know better than me, but IMO the 10 pinion with the cast iron end plates and the 1 1/8" axles is the optimal worker. I have both and have no complaints but traction is incomparable between the two IMO. It probably depends on what your needing. The 8-pinions are work horses and don't ever seem to break but the early 10-pinions have. I've worked mine pretty hard and haven't broken either one. Attention to properly installing and maintaining the axle hubs is a high priority in my book regardless of the gearbox you choose. Mirrors my experience also. Share this post Link to post Share on other sites
stevasaurus 23,812 #35 Posted August 2 @953 nut, Richard, just thinking, if @kb65's trans has the bevel gear differential...wouldn't his transmission case have the same mounting hole pattern as the manual heavy duty transmission for the 953 ??? In other words...an 8 or 10 pinion case would not just bolt on to his horse without modifacation ?? 1 Share this post Link to post Share on other sites
pfrederi 21,091 #36 Posted August 2 1 hour ago, stevasaurus said: @953 nut, Richard, just thinking, if @kb65's trans has the bevel gear differential...wouldn't his transmission case have the same mounting hole pattern as the manual heavy duty transmission for the 953 ??? In other words...an 8 or 10 pinion case would not just bolt on to his horse without modifacation ?? The mounting holes from frame to transaxle are all the same. What I am not sure about is if his Wheelamatic pump (essentially a hydro gear pump) would fit on a later piston to piston hydro transaxle as the left side case numbers are different. Still think best bet is to get a transaxle from a Charger electro hydro gear 1 Share this post Link to post Share on other sites
kb65 14 #37 Posted August 2 does that charger electro hydro gear have a 10 pinion? Share this post Link to post Share on other sites
pfrederi 21,091 #38 Posted August 2 (edited) 38 minutes ago, kb65 said: does that charger electro hydro gear have a 10 pinion? I am very sure they all do 1968-72 There were hydro gear in the no names but I am not sure what differential they had. Edited August 2 by pfrederi 1 Share this post Link to post Share on other sites
kb65 14 #39 Posted August 2 I have a local guy that has a bunch of wheel horses. if i knew for sure i could try to get one from him. 1 Share this post Link to post Share on other sites
953 nut 68,743 #40 Posted August 2 (edited) 3 hours ago, stevasaurus said: @953 nut, Richard, just thinking, if @kb65's trans has the bevel gear differential...wouldn't his transmission case have the same mounting hole pattern as the manual heavy duty transmission for the 953 ??? In other words...an 8 or 10 pinion case would not just bolt on to his horse without modifacation ?? Can't say for sure but my guess is his Sundstrand would have the same bolt pattern as the three speed did in '65. Differential wouldn't matter. Edited August 2 by 953 nut 1 Share this post Link to post Share on other sites
ineedanother 2,835 #41 Posted August 3 (edited) 5 hours ago, kb65 said: does that charger electro hydro gear have a 10 pinion? '73 Electros did. I have two. Sundstrand. Edited August 3 by ineedanother 2 Share this post Link to post Share on other sites
Lee1977 7,750 #42 Posted August 3 23 hours ago, 953 nut said: It is the same "bevel gear differential" as was used ion the 953. I have had all three, bevel, 8 pinion, and ten pinion on the bench side by side before and all three measured the same and would interchange. Wish I could find the pictures. You know, if you don't have pictures it didn't happen. I memory serves me right the bolts on the bevel gear had to go in a particular direction to work in an eight speed but would clear in either direction in the six speed. BUT, that shouldn't be an issue in the hydro so pardon my getting slightly Have I sufficiently confused the issue? My ten pinion case looks to be wider in the area behind the input pulley. It is also a lot slower in second gear then any of my eight pinion or four pinion tractors. It's 1971 six speed Raider. Share this post Link to post Share on other sites
kb65 14 #43 Posted September 1 here is where i am at. I took the 73 12 hp 8 speed apart it had a lot of good parts that i could use. when i took apart the 8 speed transaxle it did have a 10 pinion differantial. I ordered a left gear case on ebay and it has arrived. the 8 speed also had a couple of good ball bearings that i can use. As soon as i can get caught up on other projects i can work on getting this transaxle back together and hopefully get it back on the 1276 this fall between grass and snow. 1 Share this post Link to post Share on other sites
Handy Don 17,370 #44 Posted September 1 12 hours ago, kb65 said: it did have a 10 pinion differential That is the Limited Slip Differential. Good possibility this is a “6-speed”. 1 Share this post Link to post Share on other sites
kb65 14 #45 Posted September 1 the 1973 12 hp 8 speed model 10350 8 serial 904251 I had in the shed had a 10 pinion. 1 Share this post Link to post Share on other sites
953 nut 68,743 #46 Posted September 1 8 hours ago, Handy Don said: That is the Limited Slip Differential. Good possibility this is a “6-speed”. Probably, or someone got in there and swapped out the old one for a 10 pinion, they are very interchangeable. Share this post Link to post Share on other sites
