Vinnie 11 #1 Posted July 23 My son has a 310-8. The year is 1987. The main drive clutch works fine on flat ground but if you try to go up a hill, the tractor gets stuck. I was thinking the clutch plate is slipping. Do you think that is correct? An addition, would that just be tightening the drive clutch to prevent the slipping? If so, how do you do that? Thanks again for all your help. By the way my son is 11 and he loves his Wheelhorse Tractor. 1 Share this post Link to post Share on other sites
ineedanother 2,885 #2 Posted July 23 No clutch plate on that. Drive belt could be slipping or it could be an axle hub which could be damaging the axle so you'll need to narrow down where the slippage is. Most likely a worn drive belt. Look to see if the pulley on the transaxle is turning when it happens. If that pulley isn't turning, it's the belt. If it's turning, look to see if one of the axles is spinning in the wheel hub. 5 Share this post Link to post Share on other sites
Ed Kennell 47,807 #3 Posted July 23 Just to be clear, the PTO ( power take off ) clutch is only used to power the deck. The tractor drive wheels are powered by a different belt that drives the tranasxle. This drive belt is engaged by a spring loaded idler pulley that is disengaged when the clutch pedal is depressed. As stated above, there are several problems that could cause this drive line to lose power. I would connect the rear of the tractor to a tree or vehicle and then put the tractor in 3rd gear and gently engage the clutch while a second person watches the transmission pulley and belt. If the belt is moving and the input pulley is turning but the tractor wheels are not turning, the input pully key or one of the wheel axle keys may be missing or damaged. If the belt is not moving, the belt may be worn or the idler pulley belt tensioner spring may be broken. Read this thread to get a good understanding how the tractor drive train operates .310-8 Clutch Problem - Transmissions and transaxles - RedSquare Wheel Horse Forum 1 1 Share this post Link to post Share on other sites
Vinnie 11 #4 Posted July 23 Thanks so much. I was looking around the PTO and it appears to be a little bit of oil around there. I was wondering if maybe the oil is getting on the belt. These are all great ideas. I’ll take a look and see what I find out. Thanks for your help. I’ll let you know what I find out. 1 1 Share this post Link to post Share on other sites
John c 224 #5 Posted July 23 How long have y'all had this machine, have you ever seen climb this hill, is this stall/still something newly manifested. Can you smell anything when it starts uphill and stalls, like maybe a burning rubber belt, or maybe a mix of oil and burning rubber belt if the leak you mentioned is severe enough ? Share this post Link to post Share on other sites
Lee1977 7,809 #6 Posted July 27 (edited) If it's new enough it may have a gas piston, they do wear out.It's on the right side attached to the clutch shaft. I removed mine and added a Clutch spring on the left side. It's attached the clutch bracket on the left side andother end is attached to a hole on the webb on the axle housing. You have to be easer letting the clutch out with the spring. Edited July 27 by Lee1977 Share this post Link to post Share on other sites
Ed Kennell 47,807 #7 Posted July 27 On 7/23/2026 at 10:55 AM, Vinnie said: I’ll let you know what I find out. Any news? Share this post Link to post Share on other sites
peter lena 10,105 #8 Posted July 27 @Vinnie regularly see units , frozen in rust dust , area linkage / lever hand offs , just cannot do what they were intended to do , regularly use a penetrating oil first , to establish , verify movement, then follow up wit aerosol red grease , also insure that related spring pull is doing its job , make the rust run out , basic stuff , pete Share this post Link to post Share on other sites
Vinnie 11 #9 Posted July 28 Thanks for all your help. It has been running fine, so I put it on the back burner butt when I get some time. I’ll definitely take a look and let you guys know. Thanks again for all your help. Share this post Link to post Share on other sites
