cleat
314H cleanup and repair.
cleat
Finally back to working on assembling this tractor.
Mid tach plates cleaned with electronic cleaner for better decal adhesion.
1300662637_Midtachplatesreadyforcleanedforbetterdecaladhesion.JPG.48efa29f11cf71de4dfc2d228cfcbe4d.JPG
Mid tach plates decals applied.
Mid tach lock ready to be assembled.
Mid tach lock slid onto shaft then outer e clip installed.
Mid tach lock inner e clip installed.
Mid tach lock e clips all installed showing installation tool that makes installing e clips easier without damaging paint.
1990869627_Midtachlockeclipsallinstalledshowinginstallationtool.JPG.fe4fdde2738935207b826f6764c2412b.JPG
  • Excellent 3
953 nut
I had never seen the E Clip tool before,   :text-thankyouyellow:
As usual you are doing an outstanding restoration  (just as I had predicted  :ychain:)
cleat
Mid tach assembly ready to be installed onto frame.
I went with 1-1/4 and 1-1/2" long bolts likely because I used flat washers not shown in the manual.
1336133379_Midtachassemblyreadytobeinstalledontoframe1.JPG.5d1e9533cac981e58e1fb64bd5408ac0.JPG
1450445249_Midtachassemblyreadytobeinstalledontoframe2.JPG.89afe8dce49398339c8beea2d4b782a2.JPG
1290725905_Midtachassemblyreadytobeinstalledontoframe3.JPG.a3b7e92b1e15ecff454d6bcc8953eb41.JPG
2088668327_Midtachassemblyreadytobeinstalledontoframe4.JPG.84b2e1cffe6e6c3c23f621b5e837c80b.JPG
778024083_Midtachassemblyreadytobeinstalledontoframe5.JPG.b88a8fa60d00299e0abe7a563dbaae7d.JPG
Mid tach left side plate and latch assembly loosely installed onto frame.
I have temporarily used regular nuts, nyloc nuts will be installed later.
1149729065_Midtachleftsideplateandlatchassemblylooselyinstalledontoframe1.JPG.8e28ce90315c9c6a1a71141e6e414f23.JPG
1976245013_Midtachleftsideplateandlatchassemblylooselyinstalledontoframe2.JPG.95c5f51b9eb93e4e738b264e3f9df243.JPG
Mid tach plates, PTO hoop bracket, and latch assembly loosely installed onto frame.
501720311_Midtachplatesandlatchassemblylooselyinstalledontoframe1.JPG.4f710c39879d6ec892987715f53f629e.JPG
211103090_Midtachplatesandlatchassemblylooselyinstalledontoframe2.JPG.af18eb827bcd85e1c744acaf5134eb93.JPG
Clip for battery drain hose ready to be installed.
1435846215_Clipforbatterydrainhosereadytobeinstalled.JPG.28c9bbbceec3db56be38e0a79ea0e5ec.JPG
Mid tach bolts all torqued to 31ft/lb after switching to nyloc nuts.
Mid tach assembly fully installed onto frame.
934685614_Midtachassemblyfullyinstalledontoframe1.JPG.6a84e36daf7fbf8a20882e4b663cf5aa.JPG
1014422215_Midtachassemblyfullyinstalledontoframe2.JPG.55de83f1ceaca4c7408498d85ec6ec6b.JPG
237267417_Midtachassemblyfullyinstalledontoframe3.JPG.aa8b5e68f7b6c4b7b074d16cb25c1433.JPG
  • Excellent 6
sqrlgtr
Excellent work @cleat but the rows of washers, bolts and taps are a little uneven.:ychain:
  • Haha 5
cleat
New lower steering shaft front support bearing assembly ready to install onto frame.
468129964_Lowersteeringshaftfrontsupportbearingassemblyreadytoinstallontoframe.JPG.9bcf73abf42cddd4fcf4ce5075a898ce.JPG
Lower steering shaft front support bearing installed and torqued to 31ft/lb.
1235142948_Lowersteeringshaftfrontsupportbearinginstalled1.JPG.af98314784afaf68cf4bfafb6f1a7116.JPG
880783796_Lowersteeringshaftfrontsupportbearinginstalled2.JPG.e17d976d5584e726dc34ed4095d50ae1.JPG
  • Excellent 4
cleat
Frame ready to be bolted to rear end.
Hardware for rear end ready for frame to be bolted on.
724419114_Hardwareforrearendreadyforframetobeboltedon.JPG.9aa353cb7b31aff37c8c3d043ecde230.JPG
Rear end ready for frame to be bolted on.
All bolting locations thread chased so bolts screw in easily.
Alignment pins screwed into rear end.
Jack stands in place to hold up frame.
I measured from the frame mounting point to the rod in the mid tach to set distance.
Jack stands height set to hold up front of frame.
These are set to 1" higher than the lower rear end mounting bolts as the rod in the mid tach is 1" higher than the lower bolts.
1983570379_Jackstandsheightsettoholdupfrontofframe.JPG.73d2411ce3443a8e9ceff85b6e7e8ca2.JPG
Frame slid onto alignment pins and sat on jack stands.
1012334094_Frameslidontoalignmentpinsandsatonjackstands.JPG.d38abe409dc4c54cf5e3967848c9497d.JPG
Top bolts screwed in finger tight.
Alignment pins removed and bottom bolts installed then all 4 bolts snugged up keeping frame level to rear end from side to side.
Center jack stand removed as it is no longer needed.
1904306309_Alignmentpinsremovedandbottomboltsinstalledthenall4boltssnuggedupkeepingframeleveltorearend.JPG.32d396344b1b689410863a446d1ad931.JPG
All 4 bolts torqued to 31 ft/lb.
  • Excellent 3
cleat
Lower steering shaft and support block assembly ready to be installed.
Support block has new bronze bushings installed.
988082499_Lowersteeringshaftandsupportblockassemblyreadytobeinstalled.JPG.df08b417e9af7c4375e98dd9c0fedf40.JPG
Lower steering shaft bearing surface greased and never size applied to threads.
751113208_Lowersteeringshaftbearingsurfacegreasedandneversizeappliedtothreads.JPG.ceb784ac4a73e415f25ba785b7fdafb2.JPG
318063215_Lowersteeringshaftbearingsurfacegreased.JPG.da3d34107eac1a2e5c9904d49b487536.JPG
Tractor ready for lower steering shaft and support block assembly to be installed.
1676940790_Tractorreadyforlowersteeringshaftandsupportblockassemblytobeinstalled.JPG.3e9cd1a8a8c97162e3007723c6772ff8.JPG
Lower steering shaft slid into front support bearing.
186030779_Lowersteeringshaftslidintofrontsupportbearing.JPG.8f96a3a8b46376b27b64eb7863c7bd17.JPG
Steering support block slid onto lower steering shaft.
1167587572_Steeringsupportblockslidontolowersteeringshaft.JPG.877cbd4f30b3830dfc91a6d1f27d5053.JPG
Steering block bolted up loosely.
Steering support block squared up then bolts snugged.
383435564_Steeringsupportblocksquaredupthenboltssnugged.JPG.d13a46038662aeadb99b773160c78404.JPG
Steering support block bolts torqued to 31ft/lb and lower steering shaft nut just spun on a few threads for now.
95443796_Steeringsupportblockboltstorquedto31ft-lb.JPG.d953fc14bdfc3e01fb46a40064111003.JPG
Edited by cleat
953 nut
:bow-blue:               you are doing a fantastic job of documenting this build  ( I will refrain from calling it a restoration because you said you weren't going th restore it :ychain:).
One little detail that I'm sure you noticed too, the Zerk Fitting on the steering block needs to be rotated a bit more to be accessible.    :hide:
Gotta bust your chops about something and with the outstanding work you do there isn't much room to do that.     :handgestures-thumbupright:
Every time Columbo said this to the killer you know they don't stand a chance
:law-policeblue:         There is this stray thread in some of your pictures, drives me crazy!            :ROTF:
:angry-tappingfoot:
  • Haha 2
cleat
Hydraulic elbow and #906 Viton O ring ready to install.
O ring oiled with engine oil.
O ring installed onto elbow making sure nut was fully backed off and washer pushed on as far as it will go to fully expose the O ring seating area.
536829882_Oringinstalledontoelbowmakingsurenutwasfullybackedoff.JPG.30f998a1245fad5b6473fdd9c8d2c9d8.JPG
Hydro was thoroughly cleaned where hydraulic elbow gets screwed in.
Hydraulic elbow installed into hydro until the O ring is almost fully seated and the fitting is pointed town then nut snugged.
387034335_Hydraulicelbowinstalledintohydrothennutsnugged1.JPG.b509d270fca06cca3106193cef972919.JPG
376351269_Hydraulicelbowinstalledintohydrothennutsnugged2.JPG.2a17c8113d8b1b2164316992733a574b.JPG
cleat
:angry-tappingfoot:
Yea, yea. Grease fitting is now tightened into proper orientation and I will try and use the better towels from now on....
1481406744_Steeringblockgreasefittingtightened.JPG.d5e0f8ac82ab89a65f6fb937532aa879.JPG
cleat
Hydraulic tube from filter to hydro ready to install.
840198701_Hydraulictubefromfiltertohydroreadytoinstall.JPG.187fd37c72de93a821cfb6e71700267d.JPG
Hydraulic tube from filter to hydro installed just finger tight for now.
2065652742_Hydraulictubefromfiltertohydroinstalled1.JPG.357f2b6fc43857db1ac0497b261241a9.JPG
1441971575_Hydraulictubefromfiltertohydroinstalled2.JPG.5ef1506dc554daf868eaef6c8620ec97.JPG
