cleat
314H cleanup and repair.
cleat
Finally back to working on assembling this tractor.
Mid tach plates cleaned with electronic cleaner for better decal adhesion.
1300662637_Midtachplatesreadyforcleanedforbetterdecaladhesion.JPG.48efa29f11cf71de4dfc2d228cfcbe4d.JPG
Mid tach plates decals applied.
Mid tach lock ready to be assembled.
Mid tach lock slid onto shaft then outer e clip installed.
Mid tach lock inner e clip installed.
Mid tach lock e clips all installed showing installation tool that makes installing e clips easier without damaging paint.
1990869627_Midtachlockeclipsallinstalledshowinginstallationtool.JPG.fe4fdde2738935207b826f6764c2412b.JPG
  • Excellent 3
953 nut
I had never seen the E Clip tool before,   :text-thankyouyellow:
As usual you are doing an outstanding restoration  (just as I had predicted  :ychain:)
cleat
Mid tach assembly ready to be installed onto frame.
I went with 1-1/4 and 1-1/2" long bolts likely because I used flat washers not shown in the manual.
1336133379_Midtachassemblyreadytobeinstalledontoframe1.JPG.5d1e9533cac981e58e1fb64bd5408ac0.JPG
1450445249_Midtachassemblyreadytobeinstalledontoframe2.JPG.89afe8dce49398339c8beea2d4b782a2.JPG
1290725905_Midtachassemblyreadytobeinstalledontoframe3.JPG.a3b7e92b1e15ecff454d6bcc8953eb41.JPG
2088668327_Midtachassemblyreadytobeinstalledontoframe4.JPG.84b2e1cffe6e6c3c23f621b5e837c80b.JPG
778024083_Midtachassemblyreadytobeinstalledontoframe5.JPG.b88a8fa60d00299e0abe7a563dbaae7d.JPG
Mid tach left side plate and latch assembly loosely installed onto frame.
I have temporarily used regular nuts, nyloc nuts will be installed later.
1149729065_Midtachleftsideplateandlatchassemblylooselyinstalledontoframe1.JPG.8e28ce90315c9c6a1a71141e6e414f23.JPG
1976245013_Midtachleftsideplateandlatchassemblylooselyinstalledontoframe2.JPG.95c5f51b9eb93e4e738b264e3f9df243.JPG
Mid tach plates, PTO hoop bracket, and latch assembly loosely installed onto frame.
501720311_Midtachplatesandlatchassemblylooselyinstalledontoframe1.JPG.4f710c39879d6ec892987715f53f629e.JPG
211103090_Midtachplatesandlatchassemblylooselyinstalledontoframe2.JPG.af18eb827bcd85e1c744acaf5134eb93.JPG
Clip for battery drain hose ready to be installed.
1435846215_Clipforbatterydrainhosereadytobeinstalled.JPG.28c9bbbceec3db56be38e0a79ea0e5ec.JPG
Mid tach bolts all torqued to 31ft/lb after switching to nyloc nuts.
Mid tach assembly fully installed onto frame.
934685614_Midtachassemblyfullyinstalledontoframe1.JPG.6a84e36daf7fbf8a20882e4b663cf5aa.JPG
1014422215_Midtachassemblyfullyinstalledontoframe2.JPG.55de83f1ceaca4c7408498d85ec6ec6b.JPG
237267417_Midtachassemblyfullyinstalledontoframe3.JPG.aa8b5e68f7b6c4b7b074d16cb25c1433.JPG
  • Excellent 5
sqrlgtr
Excellent work @cleat but the rows of washers, bolts and taps are a little uneven.:ychain:
  • Haha 5
cleat
New lower steering shaft front support bearing assembly ready to install onto frame.
468129964_Lowersteeringshaftfrontsupportbearingassemblyreadytoinstallontoframe.JPG.9bcf73abf42cddd4fcf4ce5075a898ce.JPG
Lower steering shaft front support bearing installed and torqued to 31ft/lb.
1235142948_Lowersteeringshaftfrontsupportbearinginstalled1.JPG.af98314784afaf68cf4bfafb6f1a7116.JPG
880783796_Lowersteeringshaftfrontsupportbearinginstalled2.JPG.e17d976d5584e726dc34ed4095d50ae1.JPG
  • Excellent 3
cleat
Frame ready to be bolted to rear end.
Hardware for rear end ready for frame to be bolted on.
724419114_Hardwareforrearendreadyforframetobeboltedon.JPG.9aa353cb7b31aff37c8c3d043ecde230.JPG
Rear end ready for frame to be bolted on.
All bolting locations thread chased so bolts screw in easily.
Alignment pins screwed into rear end.
Jack stands in place to hold up frame.
I measured from the frame mounting point to the rod in the mid tach to set distance.
Jack stands height set to hold up front of frame.
These are set to 1" higher than the lower rear end mounting bolts as the rod in the mid tach is 1" higher than the lower bolts.
1983570379_Jackstandsheightsettoholdupfrontofframe.JPG.73d2411ce3443a8e9ceff85b6e7e8ca2.JPG
Frame slid onto alignment pins and sat on jack stands.
1012334094_Frameslidontoalignmentpinsandsatonjackstands.JPG.d38abe409dc4c54cf5e3967848c9497d.JPG
Top bolts screwed in finger tight.
Alignment pins removed and bottom bolts installed then all 4 bolts snugged up keeping frame level to rear end from side to side.
Center jack stand removed as it is no longer needed.
1904306309_Alignmentpinsremovedandbottomboltsinstalledthenall4boltssnuggedupkeepingframeleveltorearend.JPG.32d396344b1b689410863a446d1ad931.JPG
All 4 bolts torqued to 31 ft/lb.
