cleat 9,432 #101 Posted 10 hours ago Finally back to working on assembling this tractor. Mid tach plates cleaned with electronic cleaner for better decal adhesion. Mid tach plates decals applied. Mid tach lock ready to be assembled. Mid tach lock slid onto shaft then outer e clip installed. Mid tach lock inner e clip installed. Mid tach lock e clips all installed showing installation tool that makes installing e clips easier without damaging paint. 1 3 Share this post Link to post Share on other sites
953 nut 70,594 #102 Posted 10 hours ago 4 minutes ago, cleat said: Mid tach lock e clips all installed showing installation tool that makes installing e clips easier without damaging paint. I had never seen the E Clip tool before, As usual you are doing an outstanding restoration (just as I had predicted ) 2 1 Share this post Link to post Share on other sites
cleat 9,432 #103 Posted 9 hours ago Mid tach assembly ready to be installed onto frame. I went with 1-1/4 and 1-1/2" long bolts likely because I used flat washers not shown in the manual. Mid tach left side plate and latch assembly loosely installed onto frame. I have temporarily used regular nuts, nyloc nuts will be installed later. Mid tach plates, PTO hoop bracket, and latch assembly loosely installed onto frame. Clip for battery drain hose ready to be installed. Mid tach bolts all torqued to 31ft/lb after switching to nyloc nuts. Mid tach assembly fully installed onto frame. 4 Share this post Link to post Share on other sites
sqrlgtr 4,221 #104 Posted 2 hours ago Excellent work @cleat but the rows of washers, bolts and taps are a little uneven. 3 Share this post Link to post Share on other sites
