cleat
314H cleanup and repair.
sqrlgtr
1 hour ago, cleat said:
Tires masked ready for wheels to be painted.
1598869652_tiresmaskedreadyforwheelstobepainted.JPG.b45f57d9a70377490b6f4fd6b7150c3a.JPG
I Have yet to try the ol playing card trick. Probably just me but anytime I haven't taped up the tires with masking tape a masking paper Ive always got paint on the tires somehow.:angry-banghead:
MainelyWheelhorse
@cleat what color did you use for the rims? The 312 and 308 are due for a refresh as the 308’s are too bright and the 312’s are chipping off so I thought I’d fix that.
cleat
I have not painted them yet.
Hopefully tomorrow as it was very windy today.
I am starting with grey primer then silver aluminum paint as I have a few cans of that here.
I like a bright silver wheel on this generation.
cleat
I did the combination or cards and tape for the back wheels so I feel fairly safe there but this will be the first time just using cards for the front.
Fingers crossed I don't get paint where I don't want it.
ebinmaine
That's why Trina - aka The Paint Department - does all our work.
  • Haha 2
SylvanLakeWH
1 hour ago, ebinmaine said:
That's why Trina - aka The ENTIRE Department - does all our work.
Fixed it for ya... :ychain:
  • Haha 3
cleat
Wheels ready to be primed.
431397588_Rearwheelsreadytobeprimed.JPG.4738151e5d12a24ba1f1ae22bf192a79.JPG551450181_Frontwheelsreadytobeprimed.JPG.339b2adbb916f21ad32822f37c7a1f17.JPG
Wheels primed.
Wheels painted with silver aluminum paint.
Hoodstand ready to be primed.
Hoodstand primed.
Hoodstand painted.
Brockport Bill
how did you clean the hoodstand to clean bare metal? - - looks amazing !
cleat
Wire wheel in an angle grinder and a random orbit sander with 320 grit sandpaper on it.
The paint was poorly applied by wheel horse so it came off fairly easily.
cleat
Masking removed and tires aired to 12 PSI.
  • Excellent 4
cleat
Cylinder head removed.
Cylinder head bead blasted.
Head bolts as removed.
Head bolts bead blasted.
Head bolts ready for paint.
Head bolt washers as removed.
These are not cleaned up as I have new hardened washers to install.
Engine with head removed.
There is very little carbon buildup or obvious wear.
cleat
Head bolts painted.
Engine lifting strap painted.
Valve cover assembly removed.
